Unique Melody Tour, Impressions, & More
6 7 8 9 10 11 12 13 14 15
  1. Mimouille
    Well I have no 2.5 source, but they are making these cables themselves, so 2.5 is no issue.
  2. soundblast75
    Is this a whole new cable? not the smartest move these days, ideally one has a balanced one and then use an adapter
  3. Cotnijoe
    We offer termination in 2.5, 3.5, and 4.4. If you plan to use an adaptor, that's something you'll have to consider in advance when you choose the terminations we offer. Offering these 3 covers most bases though.
    Unique Melody Feel free to reach out to us at any time! To reach me personally, leave me a PM or email me at umwang@uniquemelody.org and I'll get back to you as soon as I can! Stay updated on Unique Melody at their sponsor page on Head-Fi.
    https://www.facebook.com/UniqueMelodyIEM/ https://twitter.com/UniqueMelodyIEM http://en.uniquemelody.org/ service@uniquemelody.org
  4. soundblast75
    I have the adaptors already, so i have balanced cables in 2.5 and 4.4 for mmcx and 2 pin, its just a massive shame the dual tone wasn't offered as such, being not your average stock cable and proprietary etc.. it now means swapping cables all the time, shame really, its so simple..
  5. soundblast75
    Actually it means having the stock cable never used anymore, which entirely defeats the point of offering a good cable in the first place
    klaimzlgd likes this.
  6. Cotnijoe
    What is the female termination of your adaptor?
  7. BrianLHR
    what material is the db-go tuning thing and the metallic part of the cable connector? they look easy to rust as far as i can see. is this so?
  8. Mimouille
    Well you can always get a 2.5 mm balanced cable and get adapters to 4.4 or 3.5 balanced. Or to single ended. But you of course cannot get a single ended cable and put an adapter to balanced.
    ngoshawk likes this.
  9. soundblast75
    The idea was to make the stock cable balanced and then offer 2.5 to 3.5 or 4.4 to 3.5..
    Now the se cable will be rendered useless after buying balanced
  10. Cotnijoe
    Not sure I follow your train of though. Is your concern buying the 3.5 SE cable and then later on buying a balanced amplifier or DAP and needing a balanced cable instead?
  11. soundblast75
    I have everything a plenty, daps, cables,adapters.what i don't have is a balanced cable for Mentors having to get a proprietary one. I am trying to say it would have been better to have the true tone as a balanced in the package rather than having to get an extra one and not use the supplied one.
  12. Cotnijoe
    You have the choice between 2.5, 3.5, or 4.4. If you need balanced, you would just choose for your IEM to be shipped with either 2.5 or 4.4. Does that solve your issue?
  13. soundblast75
    Sorry, don't understand, as far as i know ,v3's was not offered with any different than SE cable.i got Mentor 3 about 2 months ago.
  14. glassmonkey
    In spite of what is commonly believed, balanced isn't necessary for many folks. Having the stock cable be SE is still standard practice. If you order direct from UM you can get the balanced cable of your choice. Sorted.
    I would argue that the likely benefit of balanced output is small for a sensitive multiBA IEM. Balanced might just increase hiss probability. The main advantages are generally increased power and decreased cross-talk. Power is moot on an easy driving IEM. Cross-talk might not be. If your balanced output sounds consistently better, test it volume matched before reaching a conclusion. It might just be the increase in volume causing the 'better' sound.
    Lawrance, rock on.
