Unique Melody 3D Terminator 3DT Announcement Thread
Mar 17, 2021 at 10:33 PM Post #721 of 1,402
IEMusic
Florida, USA
I found that you lose quite a bit of deep beautiful sub-bass with the Spiral Dots. But if it suits you that way, enjoy, indeed!
I don’t notice a loss of sub bass with standard SDs, the sub bass is pretty much the same as with the Final Es for me. The Final Es do boost the mid bass a little, which I didn’t like. I like the imaging a lot more with wide bore tips. I do think the 3DT sounds better with shallower insertion.
Mar 17, 2021 at 10:34 PM Post #722 of 1,402
drspeter
Boston
I've been using my 3dt with sedna eartips, I guess light short version. Well I didnt do that much tip rolling but along with single crystal copper cable from xinhs, they sound amazing. Cant even imagine how further these could be improved with better tip matching and burn-in.
Mar 19, 2021 at 6:13 AM Post #723 of 1,402
Ace Bee
India
If you guys can get your hands on BGVP W01 tips, do try those on 3DT. Makes the soundstage more spacious. They are a match made in heaven.
Mar 19, 2021 at 7:05 AM Post #724 of 1,402
slex
SG/MY
Tried last nite, BGVP A07 works better on my end. Did not lost my seal while lying down on both.☺️
Mar 19, 2021 at 10:44 AM Post #725 of 1,402
Ace Bee
India
Isn't A07 narrow bore than W01? Won't that enhance the bass?
BTW, taking a long shot, are you from China? Do you have easy access to W01 tips?
Also, that losing seal while lying down is the reason why I cannot use spiral dots ++ tips with 3DT :'(
Mar 19, 2021 at 10:53 AM Post #726 of 1,402
slex
SG/MY
I reside in Singapore. Bought in Aliexpress, some in Shopee. Went for L size ( Yellow ) for A07.
Mar 19, 2021 at 11:36 AM Post #728 of 1,402
slex
SG/MY
I'm a sucker for new tips... just bought some, thanks
Go for L size, M size won't work on my end on W01 and A07. I'm use M size for others iem I owned.
Mar 19, 2021 at 11:38 AM Post #729 of 1,402
Ace Bee
India
Mar 19, 2021 at 3:35 PM Post #734 of 1,402
Kal El
Italy
UM 3DT just arrived to my home today. I wanto thank @MusicTeck for the fastest shipping from USA to Italy I've ever experienced.
I bought them with the new Hiby R5 Saber, and first impressions are very very good.
Zero driver flex with Comply Comfort 500. A bit of driver flex on the right side with JVC Spiral Dots.
After 2 hours of Spiral Dots, I've just swap them with Comply and they seem to sound fuller and with more energetic bass.
I will leave a feedback after at least 100 hours.
Mar 19, 2021 at 6:22 PM Post #735 of 1,402
slex
SG/MY
Does the Unique Melody 2HT “Terminator” have any amount of Driver Flex when inserting into your Ear?
I doubt it have but I was using foam tips, will change to silicon tips later and try ( BGVP A07 and W01 ).
