happyxcharmy
- Dec 14, 2015
Hello everyone, ^_^
I bought UERR in Aug and i am using it with UE 2.5mm balance cable and DP-X1
I am thinking of buying a new dap as I want the sound to be more accurate and a bigger soundstage. (i am satisfied with the rest of DP-X1 performance)
would u suggest me buying a new dap or just change the cable?
Though there will not be so much choices of cable for me to choose as the thickness of UE cable is the limit for my ears, my ears cant hold other cables properly>_<"
my budget is USD 1160 ( FYI, with this I can buy a second-hand AK320(USD 1095) or a brand new cowon p1(USD 1100) in my place)
It will be great if the size of the dap is similar to DP-X1 and I dont want to use an amp.
Thanks in advance !
Thanks in advance !
