seedubchris
That ship has sailed early. Over three weeks ago they offered 30% off their whole line .
I have never heard the Hugo stuff but from what I read it would be a good fit for the 18's . They are very bass centric and therefor benefit from source with clear and focused highs. I have had success with ak 320 . The dual akm 4490 dacs are super clear with lots of high end. My ak 240 was a little too soft to set them off . I also stopped using the gold/silver cable as UE would not re terminate them and I wasn't happy with the sound of the unbalanced out of the ak320. I'm not sure whether it was the UE cable or the balanced out but I went from being underwhelmed to very satisfied after pilfering the moon audio black dragon cable from my JH Michell's and attaching them to the 18"s. I went ahead and ordered a Plus Sound gold plated copper Exo as a direct result of this experience . I'm not so impressed with the cable that came with the 18's even though it was extra money. It looks a lot thinner and has an assembly line feel to the fit and finish . Not custom at all and nothing like it looked in the pictures .i think the cable is showing UE's true colors which is more about stage performance and not HiFi. All in all I would say you are in for a real treat if you can get the cabling and source right. I love mine . Just didn't think they would take all the cable rolling to sound right . Also despite what they say, they do take a bit to break in. I thought I had made a real mistake listining to them at first but they came in beautifully in the end.
Hi, I just ordered the UE18+ with “Gold Silver Copper Cable” on BlackFriday.
I am planning to buy the Mojo&Poly ( maybe only Mojo ?) or Hugo2 for my UE18+.
Any experience which is better for UE18+?
If you can wait another 3 weeks, there is a decent chance the 2Go (Poly equiv for H2) will be announced in Vegas @CES.
Recommend H2, but con is portability. Not a problem for I, but it's something to consider.
Be careful where you buy the H2 in the 852. Some go as low as HK$15K, but I believe it doesn't include warranty. I did not have too much time to investigate...
https://www.price.com.hk/product.php?p=264389
You should stop by Sim City, Jaben or Sino Centre to have a listen. For I, too many quirks non-SQ related with the Mojo. H2 is solid m8.
Be warned though. Mojo gateway --> H2 gateway --> DAVE.
Thank you so much.
I already buy the Mojo from Hong Kong. But still consider the Poly Airplay sound quality.
I try the Hugo2 the must be better, but not that crazy much difference on IEM.
But that size too difficult link to the mobile and go out. And Poly Bluetooth much better than the Hugo2 Bluetooth.
Congratulations on the Mojo/UE18+ combo. It will only get better once you add the Poly.
I miss my Mojo [SOLD] all the time.
But you change the Hugo2
How's your experience compare Hugo2 and Mojo on UE18+ or other IEM?
