- Nov 19, 2015
It really depends on what you're using your audio equipment for, the UE900 is portable and sounds great right off the bat, but has connector issues, and the stock cable isn't great, I replaced it with an aftermarket cable which vastly improved it's sound (greater sound stage depth and width, clearer mids and more textured bass). The UE9000 is wireless but seems kind of bulky, but it'll likely last longer since you can use it wired/wirelessly. I can't comment on sound since I haven't listened to them before. IMO, I'll stick with the UE900 because it's portable, and cables can always be used on another IEM (e.g. Shure) or re terminated for another connector (2-pin for sennheiser)
