hitme987
- Aug 1, 2012
Hmm..thanks for your reply.
What about the chris_himself cables? Can anyone compare the dark lord ones with the chris cables?
I had a look for you and there is some mircophonics, mostly from the earhoops flapping around but only if you leave the chin glider down is it really present. probably a little more than the stock cable (I'm not changing it to check) The cable is not $100 it's $35.00 US, remember it has a straight jack, not an L shape so putting a player in your pocket may put pressure on the jack and cable were it connects.
The build is good, nice and solid,the most improvements you will find is SQ and comfort using this cable.
