... at moderate listening levels.
Nothing new under the sun probably, but still I try to understand...
... my A-S3200 drives ATC SCM40's over half-decent speaker cables. Normally, I rarely exceed the "10 Watts" reading on the amp's VU meters (set to peak mode).
So... not exactly whisper-levels, but medium neighbour-friendly listening levels. The amp and its power supply at these levels should idle along, my assumption would be.
Still, I (and a friend) can clearly hear a difference in dynamics/snappiness (drums, percussion, bass plucks) when changing from a lower tier IsoTek Premier to the still lowly-tier IsoTek Sequel, which in one step up from the "Premier" in IsoTek's cable hierarchy.
Funny thing is, that the Premier sounds significantly more dynamic compared to the Sequel with my amp.
The design of the cables is quite similar it seems. I plugged both cables into the very same wall socket.
The obvious difference between the two types seems to be the shielding in the Sequel, other than that...?
In your experience, can power chord shielding make such an impact to an amp's liveliness at such low power level? I mean, the amp draws around 60-70 Watts of power (according to a non-professional Wattmeter) at these listening levels.
Cheers!
Sequel:
Premier:
Cheers!
Sequel:
Premier:
