elliot42
- Jul 18, 2008
Well, I now have a working Opus DAC module and have been playing with software control so that I can get an Arduino with rotary encoder and VFD to perform volume control and other control duties.
BUT, the Opus module I have is an older revision and uses the WM8740 chip and as such doesn't have I2C. I have been reading up on SPI and reading hifiduino for general info but I haven't been successful so far.
I have the DIFFHW and IWO switches pulled low on the DIP.
The Arduino is connected to the Opus using pins 8, 9 and 10 connected to MC, ML and MD (clock, latch, data).
Can anyone help point me in the right direction, tell me what I'm doing wrong, etc.
Maybe I'm not actually communicating right, or not passing the right setup commands to the Opus, or something just stupid; I'm a bit stuck...
The code I've written has been influenced by a number of sources (hifiduino included) and the bit I'm actually using to write to the DAC is as follows:
I call opusWrite in the setup() function to set the format and attenuation setting:
And elsewhere to update the volume:
Code:
void opusWrite(byte addr, byte data) { digitalWrite(OPUS_ML, LOW); spi_transfer(addr); spi_transfer(data); digitalWrite(OPUS_ML, HIGH); } void spi_transfer(byte working) { for(int i = 1; i <= 8; i++) { // setup a loop of 8 iterations, one for each bit if (working > 127) { // test the most significant bit digitalWrite(OPUS_MD, HIGH); // if it is a 1 (ie. B1XXXXXXX), set the master out pin high } else { digitalWrite(OPUS_MD, LOW); // if it is not 1 (ie. B0XXXXXXX), set the master out pin low } digitalWrite(OPUS_MC, HIGH); // set clock high, rising edge will clock the bit in working = working << 1; digitalWrite(OPUS_MC, LOW); // set clock low } }
Code:
opusWrite(REG2, 0x08); // Write to IW0(B3) bits in M2 (24-bit I2S) opusWrite(REG3, 0x05); // Write to I2S(B0) and ATC(B2) bits in M3
Code:
// Write volume with LDL bit set in addr byte opusWrite(REG0 & 0x01, (byte) volume);
