Apr 17, 2025 at 1:41 PM Thread Starter Post #1 of 6
Flipp3rix
Italy
Hello everyone!
First of all, excuse me for my bad English and if I'm off topic
(I hope I'm in the right section)
So, for many it may be a heresy, but I would need some advice for true wireless in-ear monitors with a built-in microphone.
The main use case would be to connect them to the PC via Bluetooth for work calls, but at the same time I would like to make a purchase that also works well in the music field.
I'm currently using this(Linsoul 7Hz x Crinacle Zero:2) which I get along well with both on PC and with my TempoTecV3 (wired obv), maybe there is something similar in the same format compatible with the aforementioned DAP and that sounds good?
Thanks in advance and keep up the good work!
Apr 17, 2025 at 5:20 PM Post #2 of 6
I've had the Sennheiser Momentum 3 and just got two of the Momentum 4 and they sound amazing and the mic works great for calls. Fast for watching TV or gaming too. Music sounds best with ANC and ambient mode off. Battery life is much better than the 2 version.
Apr 18, 2025 at 5:22 AM Post #4 of 6
Cool, although honestly I thought something more in the budget €50-€80. Anyway thanks a lot for the answer
Apr 20, 2025 at 12:04 PM Post #6 of 6
Hi,
Based on your request and budget, I would recommend checking out the HiFiMAN TWS450.
These are budget TWS earbuds with a built-in microphone, and provide the sound quality of a true Hi-Fi device.
Happy choosing!
Hi, thank you very much for your reply. The ones you recommended to me honestly do not inspire much confidence in me, even regarding the shape. Searching online some complained of severe latency
