BlazdiqFoods
Hi, im noob but why the concern for BA in the nozzle?BA in the nozzle too I think is too risky for 11.11... Waiting the upcoming reviews/impressions
High frequencies directly emitted to the ear canal without some kind of passive filtering.Hi, im noob but why the concern for BA in the nozzle?
It overemphasizes the treble. It can turn the IEM in a strident fatigue monster. Maybe TRN did a very smooth tuning and it is confident its fine the BA there... Only reviews will tellHi, im noob but why the concern for BA in the nozzle?
IMO it is esentially the same as tubing a BA and that's nothing to be scared of. I think the downside of putting the BA at the nozzle is that it may block the sound from other drivers.High frequencies directly emitted to the ear canal without some kind of passive filtering.
Risky for being bright or exhibit excessive ringing at a certain part of them.
They should have taken care of not blocking the sound of other drivers and namely the mids because the base can't be blocked.IMO it is esentially the same as tubing a BA and that's nothing to be scared of. I think the downside of putting the BA at the nozzle is that it may block the sound from other drivers.
The BA (or BAs for TA2) in the nozzle are for mids and treble. Only the DD bass is behind. The ideia is fine, I hope they do good this time bc those are the most cost effective Knowles IEMsIMO it is esentially the same as tubing a BA and that's nothing to be scared of. I think the downside of putting the BA at the nozzle is that it may block the sound from other drivers.
Well yikes.
and it seems like the TA is quite similar to the TA2. Personally not a fan of the TA2 as well. ¯\_(ツ)_/¯
Anyone try the BT30's? Saw posts on the 20,but search brought up nothing on the 30's. $53 right now on Ali.
https://a.aliexpress.com/_mrCbxVm
I have them and they are not a bad pair.
