TRN impressions thread
saldsald
- Dec 9, 2016
- Messages
- 197
- Reaction score
- 204
The BA5 isn't bad at all just with that tuning there is just a lot of competition at the price point. The V90s to me is one of the best in terms of stage, really good, fun and punchy bass, and most unnatural treble in a nice way. Fortunately I have no fit issue with this pair. In fact the pair fit into my ears like CIEM.I also think that these are the best headphones from this company, better than their previous model without "s"(mean just v90). But, all the same, because of the short sound guide, the issue of landing for some people will be acute.
Redonexwing
- Mar 8, 2010
- Messages
- 13
- Reaction score
- 4
What kind of eq correction curve are you guys using with the v90s?
Can't make it sound "right" to me comparing to CCA C12.
BA5 instead sounds only a bit treble muddy.
backdrifter
- Jan 9, 2005
- Messages
- 309
- Reaction score
- 241
Here are some settings you can try.What kind of eq correction curve are you guys using with the v90s?
baskingshark
So after using the TRN T300 for a few more days, I daresay it is the best TWS I have tried so far, in terms of tonality. Smooth U shaped tuning, non fatiguing but still being able to bring forward vocals and instrumentation in the mix. The bass isn't the most textured, but otherwise, I quite like how balanced it is. I've been harsh on the wired TRN releases for 2020 (for tonality), but this set is truly very atypical for a TRN tuning. No harsh upper mids/treble/sibilance fest here, if they used this tuning in one of their wired releases, I'm sure it will sell well.
The TRN T300, as expected for a TWS, won't beat wired gear in the aspect of technicalities, but I do think it beats quite a few other TWS types in this area. There's perhaps a higher treble and subbass roll off, which is also common in other wireless gear. Dynamics are surprisingly good.
To top it off, the fit is very good (despite its larger size), and the connectivity and UI is quite good. It supports wireless charging too, has a battery life indicator and charging is fast, and it has IPX5 waterproof rating. Battery life is about average, I think on a single charge, it lasted me 3.5 - 4 hours, but this perhaps depends on your listening volume too.
So as a complete package, I think the TRN T300 is excellent for a TWS, I would definitely recommend this set for TWS lovers. Good to see that TRN starts off 2021 with a bang. Now I just hope their future wired releases focus more on tonality and tuning, rather than stuffing as many drivers as they can inside and focusing on outright technicalities.
+1 on this. this is the main reason why I'm kinda intrigued by the new TA1. I like how this sounds more than my FIIL T1XS, and they are great for jogging because of the fit and tuning. I still feel like the price is a bit on the higher side because the battery life isn't as great, the 4 tap volume control is a bit annoying (if you miss 1 tap it launches voice assistant), and the included tips didn't work for me. But if it goes on sale, I think it'd be worth it just for the sound (provided you like this type of tuning of course).
sub30
Anyone have an update on the TRN TA1 giveaway on FB?
