ilovesocks
- Jan 11, 2005
Long story short: I'm recabling my ex-roommate's Triports. (Yeah yeah, "U SHOOD GIVE HIM A PIAR OF KSC-75 OR EVEN BETTER A PUNCH IN THE MOUTH LOL!!!!111 BOTH OF THEM ARE WAAAY BETTUR THEN BOSE!!" Give it a rest.)
I've put together the new cable, which is a Mogami which splits, terminated with a 1/8" Canare connector. I've tested the cable and connector with a multimeter and current travels though it quite nicely.
The problem arose when I tried to play music through a driver by plugging the connector into my amp and then touching the little wires on the driver to the appropriate ones on the cable. No matter what, I get nothing. However, if I touch the wires directly to the connector, I get sound. Again, I'm very sure that the soldering joints are solid and that the current is being transferred properly due to my multimeter testing results. I believe the problem lies in these pictures:
Bose have used a strange kind of wire for the driver; the metal strands seem to be on the outside (copper-colored and green, in this case), wound around a cotton core. What's odd is that the exterior of these strands do not conduct; only their ends do.
Now, I haven't actually tried soldering the ends of these strands to the wires of the cable because I thought I should get some input first. It doesn't seem to me that solder would help get a connection going because just twisting the driver strands to the cable doesn't work. Is there something I should treat the driver strands with in order to help them conduct? Has anyone encountered this metal-wires-on-the-outside-of-a-cotton-core kind of wire before?
Any input would be greatly appreciated. Thanks!
