Hunter use dual coil driver.
Single coil driver. Vs x2 in Master 6. New changes. Better for Master 6 guys just hoping the Hunter lives up to expectation
I guess they just updated that today. I cancelled yesterday and no charge.
Funny how that popped up today
I have vocally supported them on these threads and in PM with members helping answer questions.
Look I supported Trinity with KS. Never saw mention of cancellation fees on pre-orde. Now it's on the page.
Dang. I was not expecting that and annoyed. Sorry
Bash me if you want.
I see where you're going with regards to the whole modularity and upgrades thing with the fixed cables to the body, but I'm hoping you can explain to me the "more serviceable" aspect in regards to units with cables attached to the body. If the cable section below the y-split fails, then yes it's quite easy to replace and is even easy to test. However, I don't see how "easily serviceable" or even "easily testable" applies to the section above the y-split. If something sounds off or wrong and it wasn't the fault of the section below the y-split, then how would you know if it was the IEM itself or the the cable section above the y-split? And if the cable section below the y-split isn't to blame, then the entire upper section (y-cable and IEMs) would have to be replaced, is that not correct? I'm trying to understand how you've gotten to your current perspective of using this hardwired+y-split cable structure as opposed to the industry standard 2-pin socket (which you yourself claimed costs pennies not pounds). My personal logic points to the standard 2-pin being the overall better choice due to its universality; users are much less likely to complain about cable issues if the solution is to simply get a new cable. But you've clearly had to have thought up and weighed in on aspects of each model before coming to a conclusion, so I'd really like to hear in detail what it is you considered and how your thought process developed the current conclusion of using hardwired+y-split cabling.
Still in for my pre-order of the Hunter and would be regardless of how the cable system ends up, but my preference very much leans towards the standard 2-pin rather than the newly proposed hardwired system. Glad the pre-orders will be using the standard 2-pin style.
Would non push pull dynamics produce more bass?
They are serviceable as they will all be held together with torx screws rather than glue and interference fit. Some of our designs of the past wouldn't allow us to fix a cable as we would destroy the shell to do so. Now it will be super easy.
Don't worry about the Hunter as its standard 2 pin as noted in my first post.
From everything we have seen our new system will work better for reliability and with the long warranty what does any customer have to worry about?
Thanks for the update @Bobtrinity, I'm looking forward to the upgrade email. Your commitment to your company's goals and your customer's satisfaction is notable. I know you've had to feel beset upon with pitchforks and torches as of late, but know this, there are those of us who appreciate the fact that problems happen with almost every new product, and it's how you respond to them that matters.
My understanding is that the push pull configuration helps in reducing the distortion for a much clearer sound.
Its been in our T&C's for ages but we wanted it pointed out as no-one actually reads them it seems. If we are specially making something for specific customers (especially the Hunter) then not really on to not expect it after we start building them.
We don't usually enforce things like this as we try to be fair, but after the past few days of mass hysteria nonsense we have now and will.
Dang. So how is Hunter going to be a step above with just a single coil driver vs dual coil driver of the master 6.
Never should have cancelled master 6. Oh well
I am not real savvy but Master 6 looks even better.
The upgrade programm for PM4 will take place next year? Or we may wait for it soon enough? Thanks
