Tried Battlefield: Bad Company 2 single player with high-end CAN's and Dolby headphone - WOW!
post-6463970
Post #16 of 35
Gamerphile
Originally Posted by fraseyboy /img/forum/go_quote.gif
I concur. It sounded great on the beta.
Now if only my PC was powerful enough to run it on something less than low with playable FPS.
FYI BETA is way more demanding and laggy than actual game - its call BETA for a reason.
post-6463983
Post #17 of 35
Gamerphile
Originally Posted by Equus /img/forum/go_quote.gif
I'm sorry...I'm still gasping at the idea of using HD800's for gaming. LOL. Not that it's bad, mind you, but it sounds like a little overkill.
kinda is.. one problem I have is until I can get a good 3D down mixing algorithm with S/P-DIF out balancing them is not really true so I isn't perfect ATM....
Thats right I run my 800HD on my Headroom ultra series DAC and balanced AMP
BOOM BOOM it says.
post-6464144
Post #18 of 35
AmanGeorge
At least you're able to play the damn thing. The servers are failing big time.
post-6466598
Post #19 of 35
Gamerphile
Well I try - helps if you have friends on steam and via the internal system. All I can say is try like 20-30 servers and if that doesn't work see if the EA main servers are down again or reboot the game.
post-6469883
Post #20 of 35
AmanGeorge
Soo.... time for a thread derailment. I'm decent at MW2 (and love it), but I suck at this game. Help.
I know in theory I'm supposed to be more "team-based and objective-focused" as I play, but I don't really know what that means in practice.
post-6469900
Post #21 of 35
Gundogan
Spot.
Use your class skill (boxes, reviving, repairing ect ect).
Be crazy and creative, but patient too at times (like to let your squad spawn on you when you're near an objective).
Just plain fragging doesnt give you the 2000+ points a game all the time
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
And get your framerate high if you're playing the pc version. The game is perfectly playable @ 30 fps, but you'll do much better @ 70-100 fps
+ set your fov higher for a more smooth gameplay experience (like Quake3): http://rjdown.co.uk/projects/bfbc2/fovcalculator.php
O and the sound in BC2 is awesome ye ^^
post-6469937
Post #22 of 35
AmanGeorge
Ooooh... will watch that video when I get home, it sounds like exactly what I need.
Although it will remain to be seen whether I am a serious enough human being for Bad Company 2 to displace MW2 as my shooter of choice. I like fragging people
post-6483514
Post #24 of 35
Gamerphile
Originally Posted by Omega17TheTrue /img/forum/go_quote.gif
Some of DICE audio department must be audiophiles.
--> An Audiophile's Guide to BF:BC2 (Full)
Yeah read that a long time ago
post-6572339
Post #25 of 35
solidsnake
yep the game sounds amazing. love the footsteps in snow and helicopters flying above. (ps3 > cambridge azur 640a > d2000)
post-6576295
Post #26 of 35
freakydrew
resurecting this thread for some help....
this is the first game I have bought for my PC...usually play Wii or PS2 games.
Bought it off a reputable dealer on ebay, one whom I have bought dozens of blu-rays from with no problem.
I can't get this game to work!
I install it, everything looks good, go to play and get black screen - monitor tells me it is going into sleep mode. I have updated all my drivers and everything....
lost
I have the Asus Xonar Hdav Deluxe 1.3 - ATI radeon 4650 graphics card...I should be ok?
post-6580345
Post #27 of 35
Gamerphile
lost
yup you should be okay. Make sure the gaming is updated and your the original owner of the game.
post-6704625
Post #28 of 35
Jodiuh
so what's the optimal setup for BC2 and x-fi, something like that ? X-Fi CMSS-3D Headphone - Guru3D.com Forums
OP what are your in-game settings ? HI-FI and speakcount=6 in settings.ini ?
Anyone else have any input on this? Also, do I want Hi Fi or Home Theater? I'm still having a tough time deciding if I want to do the windows 5.1, game 5.1, X-Fi headphones w/ CMSS3D or just put it all on headphones and forget it.
post-6709044
Post #29 of 35
SoFGR
Athens
Athens
Age
32
ingame : HI-FI (it's just an EQ setting, HI-FI seems to be the most neutral )   + speakercount = 6  ,  windows control panel  : 5.1    creative audo panel  : game mode -  cmss3d headphone enabled  - evevation filter  ON
Just don't expect  miracles,  explosions and gunfire  mask  footsteps  really easily, but I'm sure you will find positioning to be pretty precise,  i can even  hear  UAVs and choppers above my head
post-6777531
Post #30 of 35
Gamerphile
Thats not true at all that is a mere simple EQ setting, BC2 has an advance audio engine that due to the low requirements of audio DSP and the many cores in a modern game system mixes far more advanced spatial and temporal effects or approximations of acustics than the primitive EAX extensions that, though I liked them for the lack of better, still is on pair with GPU's 5 years or older in that they have a very dumb and strict pipeline that can't really do much compare to what you can do with a fraction of the computing power we have today. This was okay at a time when audio processing on CPU could actually be taking significant performance but today something like 3D CMSS or Dolby Headphone run on the CPU have so close to zero impact that my tries at messureing it has not succeed on a reasonable dual core gaming system while comparing differences between different impact on performance with FRAPS etc.
