Or do you mean you can't use the cable and adapter both at a time? If so, how does it work when you use them separately?The included cable and adapter
TRI earphone impressions - I4 and I3, Starlight, NEW Starsea
Hi friend, I asked our engineer about your question, and he told me you can ignore that reminder and use the cable and adapter directly. The reminder (Says only one accessory can be used at a time) isn't related to the cables. It appears when users connect Apple devices.The included cable and adapter
ChrisOc
The Head-Fi Members' Poll is open for your votes.
It is time to cast your votes for your favourite IEMs.
https://www.head-fi.org/threads/the-head-fi-members-poll-for-iems-2021.961457/
Hi .Thanks but I went for the Monarch instead after I read the Starlight need a lot of power
Need more power ?
I don't have them but I've read the specs and are 14 ohms 103+-3 db Spl MW !
Daps with more power and higher output impedance will flatten the sound ! dongles for the extra loudness and a bit better technical performance with 0,1 - 0,2 output impedance will sound the best I guess .
Yes this definitely needs smartphone power
Yes. They are indeed easy to drive but will definitely benefit with more power. They scale well. My current favourite dongle pairing with the Starlight is the RU6.Hi .
Need more power ?
KBEAR&TRI's January Winter Clearance Event is Coming!
☆Order amount of 105 USD or more, get 5 USD discount coupon☆
☺The activity time is PST 2022.1.10 00:00-1.14 23:59☺
KBEAR official store link:
https://kbear.aliexpress.com/store/5017064?spm=a2g0o.store_home.1000001.12.5e3254acipyNKg
Sounds a very good pairing !Yes. They are indeed easy to drive but will definitely benefit with more power. They scale well. My current favourite dongle pairing with the Starlight is the RU6.
I'll probably buy the wood version . As the frequency response shows , the new wood version It might sound warmer than the original version with more emphasis on sub bass .
ChrisOc
Good choice, Max! I would get the wood casing if I were buying mine today.Sounds a very good pairing !
I am with @yaps66, the Starlights are perfectly fine using most DAC/Amps. Obviously, you have to put up the volume higher than you would with other IEMs.
However, you get a lot of more out of them with more powerful DAC/Amps. The Sonion electrostatic drivers deliver much more with more power (not volume).
For warmth try tube amps, I use the Littlebear B4X (portable) and the Xduoo MT604 fixed. You get a wonderful magical sound from the Starlights and it is not just the bass, across the frequency spectrum.
Dsnuts
- Jun 20, 2011
Grace-S is really a good cable for many IEMs from TRI.
My take on the Tri Meteor. https://www.head-fi.org/showcase/tri-meteor.25510/reviews#review-27661
I am a big fan of Meteor and Grace-S.
Give an UP to the TK2 thread! Shot by Mr. Alberto Ghizzardi
Expecting this review?
https://www.head-fi.org/threads/tri-tk-2-dual-9038q2m-dacs-headphone-amplifier.960572/post-16755103
TOP 50 SONGS this week
1. Sacrifice(Explicit)- The weekend
2. I Heard You're Married(Explicit)---The weekend
3. Expiration Date-Michelle
4. And I'd go a thousand miles--Montell Fish
5. Brave---Ella Henderson
Is there one you like? Which platform do you usually listen to music on?
Soen - Penance
Hako Yamasaki - Hitori Uta
Keiko Matsui - She Prays to the Wind
Pain of Salvation - Sisters
Theocracy - I Am
Theocracy - I Am
Happy Spring Festival!
(Some friends thought I have left here. Do not worry. This is still me, Wendy, as usual)
Are the SpinFit CP100+ good for the TRI I3? What is your opinion?
Total: 8 (members: 0, guests: 8)
