TRI earphone impressions - I4 and I3, Starlight, NEW Starsea
Feb 5, 2021 at 8:24 PM Post #1,936 of 3,471
baskingshark
Jabberwock Island
Would the I3 be a clear upgrade to the Diamond?
I still really enjoy my Diamonds a lot, heard the I3 has also nice subbass so it caught my attention.
They are qutie different like oranges to apples due to the different transducer types - single DD vs tribid with planar.
The TRI I3 is much harder to drive due to the planars inside, and sounds meh from a low powered source. So if you don't have a powerful source on hand, best to consider something else. TRI I3 is less V shaped (more of a U shape), and TRI I3 has thicker and lusher mids when amped. I think the Diamond is still bassier than the TRI I3 by a tinge, but TRI I3 beats the Diamond in soundstage when amped. Timbre is perhaps better on the Diamond. For imaging, instrument separation and details I think the TRI I3 wins here.
Feb 6, 2021 at 6:54 AM Post #1,937 of 3,471
lgcubana
S. Fl
I am picky about cable weight and feel around my ears. Is this cable heavier and/or thicker around the ears than this cable sold on Amazon?
I have the DarkJade (which should be the equivalent to the KB Ear Wide) and it takes some time, to get acclimated to; as it's stiff and on the heavier side
Search the Mid priced IEM cables thread for "Dark", for more information and feedback: link
Going left to right, the weight increases
Feb 8, 2021 at 5:46 AM Post #1,938 of 3,471
ldo77
France
On my Kbear Believe, regularly, I have the right side whose volume drops, after one to two hours of listening.
The next day everything goes back to normal.
Am I the only one?
Feb 8, 2021 at 6:51 AM Post #1,941 of 3,471
requal
Wroclaw, Poland
Feb 8, 2021 at 7:50 AM Post #1,943 of 3,471
slex
SG/MY
Feb 8, 2021 at 8:47 AM Post #1,944 of 3,471
requal
Wroclaw, Poland
I have not checked out the diameter. Click on the link and check the specifications, you may find the diameter there.
I don't see any specs..
Feb 8, 2021 at 9:26 AM Post #1,945 of 3,471
ChrisOc
London, United Kingdom
You are correct, there is no information under the Specifications tab and the Item description tab. Pity.
I would suggest you write to KBEAR on AliExpress and ask for the diameter of the Believe filter. Unfortunately, you may have to wait a while due to their holidays...Chinese New year.
Feb 8, 2021 at 2:04 PM Post #1,946 of 3,471
ldo77
France
Thanks, I'll ask to Kbear, for these filters
Feb 8, 2021 at 2:19 PM Post #1,947 of 3,471
Slater
Cincinnati, Ohio USA
Diameter is known?
Since this is a direct replacement, the diameter would be the same diameter as the stock one installed on the Believe.
Feb 8, 2021 at 7:33 PM Post #1,948 of 3,471
requal
Wroclaw, Poland
But Im looking for my Whizzer Kylin replacement mesh. As I see this is bit similar
Feb 9, 2021 at 2:34 AM Post #1,949 of 3,471
Slater
Ah, I understand. I'll measure my Believe and get you an exact measurements tomorrow :)
Feb 9, 2021 at 6:43 AM Post #1,950 of 3,471
requal
Wroclaw, Poland
Whizzer Kylin He-03 filter is 4.8 or 4.9mm.
