TRI earphone impressions - I4 and I3, Starlight, NEW Starsea
Jan 30, 2021 at 11:38 AM Post #1,906 of 3,471
requal
Wroclaw, Poland
I think I can stop dispute. I found ePro suitable for this earphone. I must buy them more, cuz I see that they are helpful in many ways. Those are most "unsealing" and light tips which I have.
Good luck :)
Jan 30, 2021 at 11:40 AM Post #1,907 of 3,471
IEMusic
Florida, USA
My right ear is notorious for causing driver flex with almost all of my DD-containing IEMs, but using the tips as stated by @baskingshark has been effective in preventing it with all of them.
I like ePro ear tips as well.
Jan 30, 2021 at 11:54 AM Post #1,908 of 3,471
requal
Wroclaw, Poland
I'm not new in this hobby. Even in this moment I have about 16 iems with no problems.
ePro are light and pressure unsealing them immediately.
Jan 30, 2021 at 1:48 PM Post #1,909 of 3,471
LoryWiv
Northern California
Do ePro tips run true to size, i.e. if I am medium with most standard tips should I buy these in medium?
Jan 30, 2021 at 1:55 PM Post #1,910 of 3,471
Poganin
Poland
Yes, width-wise they follow that size. But bear in mind they are about 3 mm longer than standard, so depending on the IEM you'll be using them with the depth of insertion may be different (shells may protrude from your ears more than usual).
Jan 30, 2021 at 2:11 PM Post #1,911 of 3,471
requal
Wroclaw, Poland
G
Size:
  • S - 9,9 mm
  • M - 12,3 mm
  • L - 14,3 mm
Normally I'm using L size tips, but ePro M is most comfortable for me
Jan 30, 2021 at 7:13 PM Post #1,912 of 3,471
IEMusic
Florida, USA
G
Size:
  • S - 9,9 mm
  • M - 12,3 mm
  • L - 14,3 mm
I also usually use large size tips, and the large ePro have the largest diameter, at 14.3mm, but the material is very soft, and not stiff at all, so I can’t use the large size tips, as the fold when I insert them. The medium size with a deeper insertion works well for me.
Jan 31, 2021 at 12:40 AM Post #1,916 of 3,471
LoryWiv
Northern California
Can you guys recommend a cable which brings out the maximum from the TRI I3?
I went with Dunu Blanche, pricey but worth it to me for for 2 reasons:
1. Pure silver adds a bit of top end sparkle, the one area I3 felt lacking in for my taste
2. Versatility with the multiple connectors
Jan 31, 2021 at 5:12 AM Post #1,917 of 3,471
Nimweth
Sussex, England
I Found the KBEAR Limpid Pro works well, pure silver and helps to bring a little more brightness up top.
