[TOUR] T-PEOS H-300 - 3 Way Hybrid - Australian Tour Thread - (Impressions / Reviews)
10 11 12 13 14 15 16 17
  1. White Lotus
    Package received!
  2. d marc0
    Highly recommended! I have these paired with either Stock tips or Comply TS200. Use Comply for a much smoother result.
  3. H20Fidelity Contributor
    Yes, it definitely works, I'm semi tempted to remove the 'grill/meshing and gain full access inside the nozzle, then we could play with adding different sizes and lengths of the foam padding. Hmm...
  4. d marc0
    I have thought of that but I don't recommend it if there's a possibility of you selling them in the future.
  5. xaddictionx
    Hmm.. Probably i'll give it a try sometime in the future as i do have extra mesh that i can replace them with. The inside should look interesting. [​IMG]
  6. H20Fidelity Contributor
    When I was using Rocco BA, I hadn't any trouble with the highs or brightness, I kept saying it didn't bother me, only from Tralucent T1 then it become rather obvious. If I could just add a little more foam I'd be happier. My problem is now I've got the mids exact where I want them but need to knock off just a fraction more highs for the T1 amp. Apart from that they really sound pretty amazing, the clarity......
  7. d marc0
    Try adding your hifiman filters... they are very thin and won't affect the mids.
  8. xaddictionx
    I believe that the polarity is reversed on the color coded cable? Anybody is having this issue too?
  9. djvkool
    Listen to Beyonce's 'Partition' song mate...my goodness...
  10. djvkool
    My review is up
    http://www.head-fi.org/products/t-peos-h-300-3-way-hybrid/reviews/10840
  11. H20Fidelity Contributor
    Excellent excellent work mate. Really see you put in the extra effort with that one.
    Big ups to you. [​IMG]
  12. d marc0
    Nicely done @djvkool ! [​IMG] I enjoyed reading your review...
    So are you finally decided in getting one for your collection?
  13. xaddictionx
    Yea! It's a must have IEM for the year 2014!!
  14. spurxiii
    Nice review. My expectation bias is now through the roof
  15. djvkool
    Thanks mate [​IMG]
    Not yet, but I am set on getting one, just a matter of when [​IMG]
