Topping TP30 Class T Headphone / Speaker Amp with USB Input
Status
Not open for further replies.
Type
For Sale
Currency
USD
Price
89.00
post-7666541
Thread Starter
Post #1 of 3
HiGHFLYiN9
Member of the Trade: Zynsonix
East Coast
East Coast
Website
www.zynsonix.com
This is SOLD
Up for sale is a Topping TP30 digital amplifier with USB-DAC. This is a very nicely put together little unit, and very versatile; it has all the features of an integrated amplifier for speakers, a headphone amplifier, and a USB DAC. As stated at Partsexpress: The Tripath TA2024C amplifier IC found in the Topping TP30 is an efficient, 2 x 15W @ 4 Ohm (or 2 x 10W @ 8 Ohm) power amplifier with separate pre amp for headphones.
Features:
  1. USB or Stereo RCA input
  2. 8 mm thick, CNC-machined aluminum front panel
  3. Class-T Tripath TA2024 BTL configuration (for 4- to 8-ohm speaker)
  4. Op-amp: Burr-Brown OP-2134
  5. 3.5 mm headphone output for headphone impedance 16 to 200 ohms
  6. DC power supply included: Input: 100~240 VAC, 50/60 Hz (US Plug); Output: 12 VDC, 5A regulator
Specifications:
  1. Output power: 15W x 2 (4 ohms, THD 0.03%)
  2. Burr-Brown USB DAC PCM2704 is a solid USB DAC solution 16-bit / 48 kHz
  3. Signal-to-noise ratio (SNR): 90 dB
  4. Dynamic range: 90 dB
  5. THD: 0.04% THD+N @ 5W/8 ohms, 1 kHz
  6. Size: 4.13" W x 1.77" H x 8.07" D (105 x 45 x 205 mm)
  7. Weight: Main unit only 1.59 lbs. (720 g); Package (including power supply): 3.3 lbs. (1.5 kg)
Guttenberg just added another glowing write up on the TP30 as one of the top ten amps from $40-450: http://news.cnet.com/8301-13645_3-20092933-47/top-10-great-sounding-amplifiers-from-$40-to-$450/
I've used the unit entirely with a pair of full range speakers and was very pleased with the performance. The unit runs $128.90 + SH @ PartsExpress. This unit is like-new, and I will offer it at SOLD shipped in the CONUS and a little more for Canada and elsewhere. It's a very well built little unit as you can see from the photo and is an excellent value.
post-7689330
Post #3 of 3
dutchcanuck
I'm interested in purchasing this off of you.  How much, all in, for shipping to Canada?
Cheers,
Ken
Status
