Marso
- Jan 31, 2015
Anyone already compared the nx1 and nx1a side by side?
which one sounds better'?
Only short experimentation with this thing so far, but using my Modi DAC and 300 ohm Sennheisers, I was able to get satisfying volume even on Lo gain with the volume knob right at 12 o'clock.
I'm also hearing the same noise from this one that I heard from the other one but the charge may be low. Maybe a charging system defect with the first one? On the back panel the red light comes on with this one when plugged in- not with the first one. If this is 'lo bat' behavior maybe that explains it. Odd for both amps to display this issue. Hope it disappears after charging. If anyone else has had this I would appreciate input. It's either a design defect or a 'lo-bat' artifact- hoping the latter. I guess I'll know in a few hours.
Where can I get 1A from, I have looked everywhere but can't find it. Also is it big improvement over old version ?
When Amazon sent me a replacement for my NX-1, an NX1A is what I got. I suspect they are simply filling NX-1 orders with NX-1A's. Haven't directly searched for the 1A there though.
I didn't have enough time with the 1 to form a reliable impression of any differences. I guess I would say they are incremental, but increments do add up. The spec'd battery life is certainly a big difference. DjBobby said there 'far more linear behavior' on the lo gain setting but I haven't gone looking for the old one. The specs that are published by Topping look quite respectable, all the more so for the price. Subjectively, quite clean even on 24/96 digitally mastered content, and develops robust output on lo gain even into my HD650's when fed from my Schiit Modi USB DAC.
Amazon USA doesn't have it listed on the site either but it's what they sent me. Can't say whether the same would happen over there though. Might be worth an inquiry.
I'm enjoying this Topping amp. I do find it changes the sound, though. It seems to make the sound stage a bit narrower but makes voices and some instruments sound more intimate.
I read earlier in this thread someone thought it increased bass and the top end a bit. I don't think it does that. I do feel more punch in the bass from a weak source but I think that's just the effect of having more power available. I don't hear more high frequencies, well, not from my cheap sources ( Xduoo X2, X3, Fiio X3ii, Ruizy X02 ).
As I said, the best thing about it for me is the way it hightens the sense of intimacy and focus. For that reason, I'm less likely to use it for Psybient music, which I listen to a lot. For that type of music I want the maximum sound stage and depth for an overall landscape sensation, which I don't think this amp does very well.
But, for vocal and acustic guitars etc, it's a champ.
