Topping DX7 - DAC and balanced headphone amplifier
Discussion in 'Dedicated Source Components' started by faber65, Mar 16, 2017.
4 5 6 7 8 9 10 11 12 13
  1. Snidel
    I'm a completely newbie.... and i would like to ask you for advice, i'm supposed to get a sennheiser hd6xxwith an 4-pin XLR cable, and i'm debating myself between this topping DX7 (on massdrop) or save and gather almost the doble for the schiit jotunheim with a DAC module. What would you do in my case?
  2. HiFi8Lover
    Daaamn.... i was about to buy the NFB-11 with the ESS9028pro, then this amp/dac showed up,
    1x 9028pro vs 2x 9018 wich is better now ? :frowning2:
  3. Levanter
    FYI the DX7 ess 9018K2M is a mobile DAC chip while the 9028Pro is a desktop DAC chip.
    2x 9018K2M = 2x2 channel while the 9028pro alone is 8 channel if I'm not mistaken.
    Jimster480 likes this.
  4. garchy
    Hi, I'm newbie and I have doubts. With which headphones can come well the topping dx7?
    Its price is very attractive.
    Thank you
  5. crabdog
    I've been using it mainly with the Acoustic Research H1 running balanced. Pretty awesome. It also works really well with sensitive IEMs. I love it.
    trellus likes this.
  6. garchy
    I'm glad to hear that ... it looks versatile.
    Thanks crabdog
  7. garchy
    Some comparison with other ampli / dac. Audio gd, matrix mini, etc.
    Thanks
  8. Jimster480
    Just saw that this came out, thinking of ordering it!
  9. Jimster480
    8 channels means little if you are listening to music xD
    Kuh-Fi likes this.
  10. domsch1988
    Man, decisions, decisions.
    D30/A30 Stack, DX7, O2/ODAC Combo, Meier Corda Rock plus my 2i2, Aune x1s
    The "up to 350€" Range sure is crowded as hell. How should any beginner be able to decide between all this ^^
    mindhead1 likes this.
  11. Jimster480
    Honestly DX7 actually has some worse specs, but if you want balanced + 6.35mm then.... There isn't much choice in that segment.
  12. crabdog
    Well I'm really enjoying the DX7 so far. Like Jimster said, if you want balanced - choices are a lot more limited. It works great, doesn't get hot and I'm a sucker for devices with a display screen :nerd:
  13. Jimster480
    I'm debating on buying one just because.
  14. moby1974
    Anyone tried or have idea if it will power LCD-2f, also the sound, bright? neutral? little warm? warm?
  15. crabdog
