gto88
- Dec 11, 2014
Sorry to hear that.
Hope it works out for you.
I am sure you have tried this, but just in case... Disconnect the DX7S, uninstall the Topping drivers, reinstall the drivers, reconnect the DX7S... Maybe it's something as simple as that...So, I just got mine a week ago, and... it's dead now. Well, in the least, it's completely stopped being recognized by my PC as a USB device. Optical in still works. I don't have another system to test it out on, but there's nothing that hints me toward it having anything to do with my PC. I can say that it's not the cable. Very excited to test out their customer service, which I'm sure isn't going to at all be a huge hassle. While I wait their response, however, I'm cracking mine open to see how bad the heatsink problem is. Hugely bummed out by this; I don't really have the money to throw around on expensive crap that stops working in a week. Sounded good for that week though.
I originally wasn't using the Topping drivers at all, as it seemed to work fine out of the box with Win10. I did try installing them once the problem arose (at first Windows still recognized the device but it wasn't outputting sound, then it completely stopped recognizing it), but the drivers couldn't detect a connected device either. As it is, there's nothing else to try uninstalling and reinstalling, and it's not even showing up on the Windows Device Manager, so I can't do anything in there either.I am sure you have tried this, but just in case... Disconnect the DX7S, uninstall the Topping drivers, reinstall the drivers, reconnect the DX7S... Maybe it's something as simple as that...
I have never found an output level that would work for both headphone out and DAC out.Question to DX7(s) owners, when i set it to DAC+HP mode so I can control
volume on DX7s, as I listen headphones at -38DB or so, its DAC output is to low.
But, if I turn it up for external AMP, then the headphone that connected would be too loud.
So, what do you people do about this mode, I want the HP plug in, so I don't have
to plug/unplug every time I change to DAC+HP mode.
Is it possible? or it is either dac or HP never the dac+hp?
Then, the dac+hp mode seems not practical at all, is it?
Yay!Okay, so after four (probably unnecessary) computer restarts and taking the whole thing apart, it started working again? When I plugged it back in after having it disassembled, I noticed that the sample rate on the display read "---kHz". The whole time it was not working it was stuck at "44.1kHz" even though it shouldn't show a sample rate when it's not connected to a PC. Sure enough, once I reconnected the USB cable the sample rate display updated as you'd expect and it once again was being recognized by the PC. Very peculiar; I'm guessing it fully losing power caused it to reset whatever was going on to make it frozen in the way it was. I don't know what version of the firmware this shipped with, but I'm going to update it now.
Yes, the same has happened to multiple others. Sometimes the USB inputs freezes up, and disconnecting all power (including the USB and power cables) for 10s or so can fix it.Okay, so after four (probably unnecessary) computer restarts and taking the whole thing apart, it started working again? When I plugged it back in after having it disassembled, I noticed that the sample rate on the display read "---kHz". The whole time it was not working it was stuck at "44.1kHz" even though it shouldn't show a sample rate when it's not connected to a PC. Sure enough, once I reconnected the USB cable the sample rate display updated as you'd expect and it once again was being recognized by the PC. Very peculiar; I'm guessing it fully losing power caused it to reset whatever was going on to make it frozen in the way it was.
I used the DAC+HP mode all the time because then it functions as a DAC and preamp into a separate power amp. But then I don't have headphones connected. DAC+HP is definitely a misnomer for this mode.Question to DX7(s) owners, when i set it to DAC+HP mode so I can control
Obvious reason to have the DX7S volume knob control the DAC output is if using the DX7S as a preamp.Yes, the same has happened to multiple others. Sometimes the USB inputs freezes up, and disconnecting all power (including the USB and power cables) for 10s or so can fix it.
In DAC mode the rear outs are at full volume, in HP mode they are off. When using the external amp, do you need the DX7s's volume control at all? Are you switching back and forth between the DX7s and the external amp or something like that? Otherwise I'd indeed switch to DAC mode for the external amp and to HP mode when listening with the DX7s. It should remember the volume level.
True. For transparency, I'd rather use a lower gain setting in the amp than use the DAC's volume control, but that is a legitimate use case. It could also be useful to volume match another source for A/B comparisons.Obvious reason to have the DX7S volume knob control the DAC output is if using the DX7S as a preamp.
The reason I know of to use the DX7S volume control for DAC output when it is connected to an external amp is if the DX7S output voltage swing would cause clipping in the amp... an example of this is the MD THX AAA 789... if the 789 is at the highest gain setting the DX7S output voltage swing at 0dbfs is too great - the DX7S output needs to be set to -6dbfs in that case.
But, yeah, HP+DAC is at best a misnomer. In reality it is well intentioned, but given that no setting is useful in both cases and thus is dangerous to your headphones and hearing it is ultimately a bad design choice - that mode should be something like “DAC-V” for variable DAC output and should not also drive the headphone output.
But, hey, given the 10 ohm output impedance on the headphone out on single ended and 20 ohm on Balanced, only high impedance, or planar, headphones should be used... I see the headphone outputs on the DX7S as a pretty useless/limited feature if you own a decent amp with sub-1 ohm output impedance.
