lacknothing
Don't forget this headphone out of the Topping is not meant for TRRS plugs.
Simply don't use such.
The issue @voon was experiencing was incidental to the TRRS configuration. He measured over 8 VDC offset on one channel, which will overheat most voice coils.Hmm... I have used TRRS connectors with no issues, both on headphones and iems.
Got my DX3 Pro for about 3 days now. Got it for €140 in China during 12.12 on Taobao. haha A PROPER bargain. I'm gunning for the D50 at the same price at 1.1.
I have to Say I'm quite impressed with the little unit! It's even driving my 600 ohm Beyers dynamics pretty decently!!! When I do A/B comparison with my highly customised Lehman it's maybe not as tight or refined in the details but this is really marginal! Nothing lacking in power and also about clarity or transparency I have nothing to write bad about. It's musical and natural sounding with loads of power. NOTE: This is with a high quality ultra low noise Linear power supply of 1.5A instead of the 1A switching supply. The original switching supply can't keep up with the 600ohms to be fair. Lacking bass mostly and refinement.
The DAC is fine! To my sadness I don't have any DAC to A/B compare it to other than my onboard ES9018K2M since all my other DACs have left life in the past year. A bit unlucky. So no A/B comparison other than saying it's WAY better than the onboard ES9018K2M in my laptop haha. Which is super muffled in the highs and veiled.
My observations about the DAC are simple. It's transparant. It's musically pleasing. Naturally sounding. I'm loving it so far. I do look forward to an A/B comparison with the D50 ESS counterpart. Once I do, I'll surely post my findings here.
Thanks for sharing.
You supplied the DAC with 15V LPS instead of the original 18V?
I've just noticed the LPS you're using with your DX3 Pro - that's the same one I have on order. I already have an LPS with my Topping D50 so will be able to do a comparison between the two DACs soon.
I got my CR2032 battery today so I could power the remote. The remote for the DX3 Pro is quite necessary for ease of use. You could control everything from the multi-function button on the DX3 Pro itself but it's going to be a world of pain. I'm wondering whether it's possible to buy the remote control separately as I wouldn't mind having a couple of spare ones?
Anyway, in preparation for some extended listening I've set the DX3 Pro up in my bedside headphones system, swapping out my Topping D50. Setup is:
Bluesound Node 2i (streaming Tidal HiFi) > Topping DX3 Pro (via coax) > Arcam rHead headphone amplifier > beyerdynamic Amiron Home over-ear headphones.
The DX3 Pro is powered using its supplied 15V 1A power supply, although I do have on order a 15V 1.5A linear power supply that I'm hoping will make an incremental improvement in the sound.
Configuration of the DX3 Pro is:
Interconnects:
- Input signal: Coax
- Output setting: DAC
- PCM filter setting: F-3 (default)
- Screen brightness: L-1 (low)
- Auto power: A-0 (On - deafult)
- Headphone amp gain: 0dB (although this will not be used as the DX3 Pro is in DAC mode)
Network streamer > Topping DX3 Pro: QED Reference Digital Audio 40 w/ Digiloc RCA Plugs 0.6m
Topping DX3 Pro > Arcam rHead headphone amplifier: QED Performance Graphite Audio Phono / RCA Cable 0.6m
Initial thoughts, and comparing the sound to the Topping D50 that I've listened to for a few hours per day over several weeks: the sound is slightly warmer. It seems a touch more musical and, therefore, enjoyable. The output on the RCA analogue jacks might be slightly lower compared to the Topping D50 as I had to turn the volume control on my headphone amp up slightly more.
Playing some very familiar songs, the vocals grabbed me even more than with the Topping D50. The nuances in a singer's voice were slightly more noticeable. Bass was pretty much the same as the Topping D50. As for the treble notes, I'll have to listen more to see if I can spot a difference. These are just initial impressions from powering the DX3 Pro on for the first time and listening for about an hour.
It all looks very positive.
Taz, where did you order the 15V 1.5A linear power supply, please?
My co-worker got a DX3 Pro, I used my Beyerdynamic DT 990 250 Ohm on it and I really enjoyed it. It really got them loud with the stock adapter, uncomfortably loud at -5db. But still for the future, if I buy one too, I'd like the 1.5A adapter.
That's pretty good news! I thought the D50 might have a better DAC circuit.. So I was tempting to buy it and test it against the DX3 Pro but seems there is no need for that haha. So far I don't really use the Headphones out since I have my Lehman with Burson V6 hanging behind it to drive my monitors and headphone. but I the LPS definitely improved the headphone amp in the lower frequencies. I heard no noticeable difference when using DAC only.
From here: https://www.ebay.co.uk/itm/271905173892
If you want to hang on for 1-2 weeks I can report back to say whether it improved the sound or not.
