Tips for Sound Magic PL50?
Oct 4, 2010 at 3:19 PM Thread Starter Post #1 of 7
A.Mir
Sorry if this question has been asked before but when I used Google nothing helpful really came up.
I'm happy with the stock foam tips that come with my PL50. They fit my ears perfectly (haven't tried the silicone yet). The only problem is that I don't know where to buy the foam tips if I should need more. Searching on the Internet tells me that these foam tips aren't just "industry standard" but specially made for the PL50 (or am I wrong?).
Has anyone tried the PL50 with other foam tips and what were your thoughts?
Some say SONY Hybrids are the way to go but what about foam tips?
Oct 5, 2010 at 11:34 AM Post #4 of 7
As far as I know, there are a few cloned Sony hybrid and Monster tri-flange on eBay, but as far as foam tips go, almost all are the real stuff.
Apr 21, 2011 at 2:14 PM Post #5 of 7
I own a pl50, and Im from India, can you help me with some more information regarding how I could get me some foam tips. I previously bought tips but they did not fit.
Apr 21, 2011 at 9:32 PM Post #6 of 7
If you can't find a store near you that carries Shure (which generally also carries their foam tips as well), the only other solution I can think of is to get them from eBay.
Apr 23, 2011 at 3:30 AM Post #7 of 7
In mumbai, india, there are not many stores where I can find very good iems,
Not to mention iem accessories.
I found this on ebay,
http://orders.ebay.in/ws/eBayISAPI.dll?ImportHubViewItem&itemid=200366886480
can you tell me if it is compatible with pl50?
Also I want to buy some triple flange tips too
Which out of these will fit the PL50?
http://shop.ebay.in/i.html?_nkw=shure+triple+flange&_sacat=0&_odkw=shure+ear+tips&_osacat=0&_trksid=p3286.c0.m270.l1313
Do you think the price is right or are there any better tri flange tips at a better price?
