Tin Hifi P1 impressions
post-15570548
Post #1,156 of 1,172
Krassi
Cologne, Germany
Cologne, Germany
...The dreamteam setup with hptoy preset :wink:
Reactions: muths66
post-15571375
Post #1,157 of 1,172
capnjack
England
England
There is also a new Harmon curve P1 preset in the HPtoy app that I noticed while playing today.
Reactions: Krassi
post-15571627
Post #1,158 of 1,172
Yogibear91
harrogate
harrogate
this one's perfect for me with bass on :)
Reactions: capnjack
post-15583645
Post #1,159 of 1,172
eclein
Pennsylvania
Pennsylvania
Got a pair of P1s coming from trades here, any tips on cables or eartips?
I know they are hard to drive and should be ok with that. Thanks.
post-15584043
Post #1,160 of 1,172
HiFlight
Fort Myers, FL
Fort Myers, FL
I can highly recommend the Triton8 legacy OCC copper cable. It is available from TritonAudioCables, owned by a highly-regarded longtime Head-Fi member. That, combined with with the Spiral Dot ++ tips, to my ears, makes my P1 one of the most enjoyable IEMs I have owned.
Reactions: eclein
post-15584072
Post #1,161 of 1,172
Yogibear91
harrogate
harrogate
fiio mmcx 2.5mm or **** 16core 2.5mm
the foam tips they come with are pretty killer in my opinion better then what comes pre installed
Reactions: eclein
post-15584478
Post #1,162 of 1,172
samandhi
USA
USA
Well, they are not really hard to drive per se', but to drive them to full potential is another story. As to cables and tips, it is going to depend on several factors. I find the Tripowin C8 works well with them, but that is on the cheaper side of cables (cable 175 is recommended, but a bit more expensive). My choice is the 4.4mm balanced, but that will depend on what you are listening to them from (I use it on the DX160 which has about 1.2Watts out of balanced and .4 output impedance, or something close to that). I also like the Final Audio Type E tips, but also find the stock tips actually fit me very well. Point is, I am a detail craver, so I like an SPC cable (not copper, but pure silver is too much), and small bore long style tips. If you need a warmer sound, or you are super treble sensitive (though they are never sibilant), go with a copper cable and/or wide bore tips. This will warm the treble a bit, and give more quantity of bass.
To give them a bit wider sound stage, I have taken a pair of older tips and cut out the core, then cut those (cores) into about 1/2 to 3/4 of their height and put them on the stem as a spacer to keep the tips out as far as possible. Works perfectly for me, but YMMV. Just keep in mind that with these the tip fitment is paramount to getting the full potential sound, moreso than any other IEM I have listened to.
Reactions: eclein
post-15584541
Post #1,163 of 1,172
eclein
Pennsylvania
Pennsylvania
I have 2020 DX160 in Blue on the way!
Reactions: samandhi
post-15587948
Post #1,164 of 1,172
eclein
Pennsylvania
Pennsylvania
I received the P1s and they aren’t that hard to drive for me and sound perfect with the white foam tips they came with. This is the sound signature I’m enjoying more and more. Stock cable and foams (just were dropped off) so the amazement continues and trial and error changes in tips etc will commence after I float with these for a few days...!
Reactions: samandhi
post-15588056
Post #1,165 of 1,172
samandhi
USA
USA
Are you using them with the DX? And you are right, they are not really hard to drive, and may sound perfect (for your ears) out of a phone jack. But if you add more power to the mix, you will get a bit bigger soundstage, better textured bass, and more detail retrieval (or in short they won't sound as flat as they do when under-driven). I would enjoy them right out of my phone had I not had the DX, and had ordered a 4.4mm balanced cable. I don't believe that the balanced connection alone makes any headphone sound better (IMO), but in this case we are talking about Orthodynamic phones, and the DX only puts out 391 milliwatts out of 3.5mm SE, but puts out 2.1 watts from the 4.4mm balanced. The concensus on this thread (and other sites I have read about these IEMs) says they really need at least 500 milliwatts to be at full potential. Enjoy! :)
I would like to hear your impressions on them after spending a couple of weeks with them consistently?!
Reactions: eclein
post-15588107
Post #1,166 of 1,172
eclein
Pennsylvania
Pennsylvania
The new Dx160 is coming Monday and I bought the new adapters with it so I can use my 2.5 balanced for the 4 etc.
I new phone yesterday so all my stuff like pictures are not all here yet but they are angled adapters with a clear portion showing the traces. I can dig up pics
tada!
Reactions: samandhi
post-15591025
Post #1,167 of 1,172
eclein
Pennsylvania
Pennsylvania
DX160 came yesterday overnite from Hong Kong and I decked the P1s in a balanced copper cable with those Comply foam globes for tips.
They sound awesome using balanced output. They easily sing with this Metallic Blue unit...!
Reactions: samandhi and Cevisi
post-15591267
Post #1,168 of 1,172
samandhi
USA
USA
It looks like your coming out of the SE output on both pictures?! Did they flip the ports on the 20 version? On the 19 version the 4.4mm balanced port was on the bottom left, while the 3.5mm SE/LO was bottom middle.
Gratz on your new DX! Looks nice. I have the silver 19 version and still love it as much as I did the first day I got it.
post-15591363
Post #1,169 of 1,172
eclein
Pennsylvania
Pennsylvania
The pictures are not specifically showing anything but color. The ports didn’t change .
Reactions: samandhi
post-15654812
Post #1,170 of 1,172
Draknodd
Reactions: xxAMAROKxx
