Thoughts on a bunch of DACs (and why delta-sigma kinda sucks, just to get you to think about stuff)
post-11742971
Post #6,182 of 6,423
miceblue
Finally found a technical video that shows Sigma Delta has issues with tracking fast changing(very steep sloping) signals: It is called Slope Overload Distortion. Also Sigma Delta has Granular Noise distortion.
https://en.wikibooks.org/wiki/Analog_and_Digital_Conversion/Delta_Modulation
Watch From 28m:50seconds onwards:
Interesting to note, but how applicable are granular noise and slope overload issues for multi-bit DS-modulators, which is basically everything out there these days.
post-11743242
Post #6,183 of 6,423
Jozurr
  Hey guys, could use some help.
I need a DAC preferably under 200$ (unless there is one near 300$ that is A LOT better).
My gear: Audeze LCD-2 Rev 2
Gustard H10
Lossless files
Want a USB connection to computer
My goal is a setup with bass extension, slam, and control.
Thanks.
Have the same question. Can you guys please suggest some warm sounding DACs in that price range (closer to $300). I tried the iDSD micro but still doesn't feel as "blended" enough as I imagined it would be.
post-11744005
Post #6,184 of 6,423
haywood
Your best move would be to save coloration for the amplification stage. You want your source to be neutral.
I haven't heard it but the new LH GOv2 is supposed to be very good (and relatively neutral). If you can wait and your budget is 500+ then rumor has it that might be a good idea.
post-11744162
Post #6,185 of 6,423
DecentLevi
Seattle area
Seattle area
Yes the above mentioned DAC has gotten some very good reviews (holding out to say more until I try it).
That's a good point about wanting the DAC to be neutral - this way it can be like a chameleon - presenting everything the way it's supposed to be, so you can let the rest of your source chain do the coloring: the amp and its' tubes or op-amps, any software or hardware EQ'ing and of course the way the headphones present the sound signature. Otherwise a DAC with a character of it's own would plague the rest of your chain by presenting everything falsely.
post-11744329
Post #6,186 of 6,423
BassDigger
In at the deep end.
In at the deep end.
Well, I think that it's a valid question; hasn't this whole thread been about the varying sound signatures of dacs? Some say that even the mighty Yggdrasil can sound a bit forward (less warm), when compared to some of it's competition!
But of course, there's a lot more to getting the sound that you want than just choosing the right dac.
post-11744917
Post #6,187 of 6,423
jcx
post-11744993
Post #6,188 of 6,423
jimvibe
Gosh, why does this thread have 400+ pages of comments? Studio ADCs and DACs use D-S modulation and most relatively modern recordings went through numerous analog-digital / digital-analog conversions which means if there do exist D-S imperfections they are already on the recording and nothing can be done with it. Moreover I am willing to bet money that nobody will be able to tell the audible difference if Benchmark DAC1/ADC1 (D-S of course) combo is thrown in the signal chain that ends with say Schiit Yggdrasil.
post-11745079
Post #6,189 of 6,423
jcx
of course you would have cripple the cognoscenti's golden ears here with level matching, blinding protocol...
Reactions: maverickronin
post-11745091
Post #6,190 of 6,423
Wildcatsare1
Ah.....so this is the reason 90% of the recordings made since 2000 or so, sound so bad......
post-11745151
Post #6,191 of 6,423
miceblue
^ Yup, it's totally the DACs that make recordings sound bad. It's for sure not the Loudness War at all, no way Jose. That would be silly.
post-11745167
Post #6,192 of 6,423
frenchbat
how much money are you willing to bet ? Set the test, I'll take it.
Hint, I have a Dac1 hdr and a theta dspro genV
post-11745181
Post #6,193 of 6,423
jimvibe
Hint: You might want to add a decent voltmeter to that combo before actually agreeing to do a test :)
My point is that ADC1/DAC1 will not add any coloration to the sound. And if you prefer the coloration your theta does, you will still have it regardless of analog-digital-analog conversion in your chain.
post-11745185
Post #6,194 of 6,423
Wildcatsare1
Do you think it could be a combination of both MiceB? Probably, and the "applefication" of creating musical pablum for the "masses".
post-11745196
Post #6,195 of 6,423
frenchbat
Details and ambiance cues are not a coloration, but regardless, if you consider there's a coloration, how would it be possible to not hear a difference ?
