Thoughts on a bunch of DACs (and why delta-sigma kinda sucks, just to get you to think about stuff)
post-11717603
Post #6,046 of 6,423
Sapientiam
Good analogy - the carpet in the case of S-D DACs is the measurement tool, the FFT.
post-11717629
Post #6,047 of 6,423
evillamer
Woah! Tyll will be the first professional reviewer to take on the Schitt Yggdrasil!
http://www.innerfidelity.com/content/big-sound-2015-and-so-it-begins
 DAC/Amps
AURALiC Vega DAC ($3499) and Taurus MkII ($1899)
Simaudio MOON Neo 430 HA ($4300 w/DAC)
HeadAmp GS-X Mk2 ($2800)
Schiit Ragnarok ($1699) and Yggdrasil ($2299)
Woo Audio WA-234 ($15,900)
Apex High Fi Audio (TTVJ) Teton ($5000)
Eddie Current Black Widow ($1248)
Violectric V281 ($2299)
KGSSSRE (Kevin Gilmore Solid State Special Reviewer's Edition E-Stat Amp ($Unobtanium)
post-11717692
Post #6,048 of 6,423
abvolt
California
California
That should be a good read..
post-11717732
Post #6,049 of 6,423
vhsownsbeta
Most definitely.
OT but it will be interesting to hear how Eddie Current BW holds its own amongst such company too...
post-11718363
Post #6,050 of 6,423
rkt31
agreed that high end DACs are more about individual tastes but the review about Hugo is surprising as in last one year only this is the negative review of hugo i have read at least for sq and that too for the Treble for which it is most regarded amongst the high end dac. not many reviews of yggdrasil vs Hugo are on the net but I have read some where that yggdrasil has bright Treble which won't suit the every recording. hugo on the other hand differentiate between poor and good recording which but in a more transparent way. it adds nothing to either Treble or bass just refined clean flow of music ! no wonder one reviewer on headfi preferred Hugo with lcd 3 over yggdrasil with lcd 3 with same headphone amp. so my suggestion tread with caution for over enthusiastic reviews of yggdrasil and audition both specially with more dynamic classical recordings. also 2qute is same as Hugo and priced much below yggdrasil.
post-11718693
Post #6,052 of 6,423
Staxton
I'm sorry if I missed this, but which negative review of the Hugo did you read. I would very much like to see that.
Thanks.
post-11718826
Post #6,053 of 6,423
jcx
the Fourier Transform is just another tool to look at the data with - shows some things to human eyeballs, our visual pattern recognition that are harder to see in the time domain data
but it seems popular for some to mischaracterize it - a common naive criticism is that the Fourier data is "averaged" - like the carpet smoothing the "bumps" - implying something is "lost"
the conventional understanding of averaging does involve information loss - and therefore isn't a useful way to think about the Fourier Transformed data - because the Fourier full complex data is a Mathematical Dual of the Time Domain data
you can convert the full complex fft phase and magnitude data points back and forth to the time series data with accuracy limited only by your computer arithmetic wordlength
a good illustration of the Dual property is that a "single point" Diac impulse in the time domain gives a result in every fft bin with constant magnitude and a smooth phase variation that encodes the time occurrence of the time domain impulse
the Dual situation is the impulse/single point in the fft plot represents a smooth continuous sine wave with differing values in every time domain data point - the sine phase relative to the data record start coming from the arg of the complex fft data point
but all of the information is preserved in either view - just what is localized is different - and is the power of looking at the data in both domains
post-11719010
Post #6,054 of 6,423
Sapientiam
Nice explanation - the 'averaging' that occurs (without data loss) is because the FFT is a histogram, a point lost on not a few people who present data with it as if its a graph. So merely being presented an FFT plot hides some vital information - the bin bandwidth. The various mis-presenters then go on to point to a 'noise floor' (when the 'line' of grass is fairly straight and horizontal) and claim that's the noise floor of whatever they were measuring.
post-11719068
Post #6,055 of 6,423
asdfg
WARNING: BAD TRADER
Darn, that is actually an extremely detailed list man. Keep up the good work!
post-11719202
Post #6,056 of 6,423
jcx
I don't find your distinction any more or less relevant than saying a digital audio time series single number is a "bin" of the continuous signal "average" over the intersample time
interpreting fft bins does require knowing record length in addition to sample rate because frequency is inherently a distributed in time concept
but that really isn't "extra" knowledge - count the bins and look at the frequency axis labels - no different from getting time domain record length form sample rate and number of points
with effective bandlimiting, complying with the Nyquist limit, the digital audio time series of numbers are a practical, useful, even sometimes musically satisfying representation of the continuous signal
with Shannon-Hartley Channel Capacity Theorem the Analog noise floor also puts a practical limit on the bit depth needed
“So merely being presented an FFT plot hides some vital information" doesn't seem to be relevant to engineers applying the tool to find evidence for or against Delta Sigma possible error vs R-2R DAC
it really doesn't seem to be useful to harp on the limitations poor popularized presentations in a way that could easily discredit a valuable tool in the minds of people without the speciallized education – as the carpet analogy seems to be trying to say
post-11719421
Post #6,057 of 6,423
purrin
aka Marvey, purr1n
Member of the Trade: Eddie Current
You should follow your own suggestion of listening to both DACs.
Reactions: Ableza
post-11719992
Post #6,058 of 6,423
DreamKing
OK, understood, you are correct on the numerous variables present and the very subjective ways we all interpret them. I have never had a treble problem with the 560, others find it very annoying.
My problem with the O2/ODAC is also subjective, tonality is critical to me, they just didn't sound natural with multiple headphones. Others love the Audeze "House Sound," I don't. While I love the 560 and HE6, many of those who like Audeze don't care for them.
What I try to do on Head Fi and in reading the Audio Literature is find those with similar tastes, biases, and objectives, then learn vicariously through their experiences.
In the end, I agree with you even if I have my different way of looking at essentially the same thing and I personally think headphones still have a lot of ways to go, easily more than any other kind of gear. I think the booming VR development is going to advance research in HRTF binaural technology so I expect to see some amazing stuff soon on the hardware side and software.
post-11720009
Post #6,059 of 6,423
skeptic
  the link between feedback errors and slewrate was the source for some controversy in JAES in the '70s when Matti Otala started publishing his theories on Transient Intermodulation Distortion - there are links depending on the amp electronics internal design, Otala incorrectly assumed a particular linkage was unavoidable and dogfights ensued his fundamental assumption has been shown wrong in theory, by hardware realizations, custom built measurement hardware using his TIM definitions - but it is a powerful meme that many wanting to criticize high feedback amplifiers have refused to give up
another thing that has happened without getting credit from Otala/TIM adherents is that over time op amp manufacturers have improved the semiconductor processes and internal circuit topologies - modern chips intelligently selected for the application have vanishingly small slew rate caused errors for audio
and that's off a "baseline" of NE5534, TL072 that managed ~ 10 V/us in the '80s
just take a "prosumer" $150 sound card like the ESI Juli@ and try to show TIM in analog loopback - despite the only slightly better than generic op amps - certainly not using anything a "op amp roller"would put in, "audiophile" manufacturer would brag on (if they admitted to using op amps at all)
Thanks for this explanation - very interesting!  Notwithstanding that it sounds like Otala's theory of unavoidable TIM from feedback amps has been disproven, would you say that there is general acceptance for Pass' comments in the article I previously linked - that negative feedback - while dramatically lowering overall distortion, noise, output impedance, etc. - increases non-linear distortions and higher order distortions?  (See, e.g. figures 10 and 11 - https://passlabs.com/articles/audio-distortion-and-feedback )  I have sort of taken this article as gospel as to what is measurable (audible in controlled tests being a separate issue), but would be interested to know if Pass' assertions are controversial among audio engineers.
I know nwavguy emphatically argued that 1.5V/us should be adequate for any headphone amp and then basically doubled that in designing the o2.  After reading bits and pieces about TIM and slew rate though, I ended up building agdr's booster circuit and swapping out the input opamp for a pair of lme49990's, which bumped it up to around 20V/us (see http://www.head-fi.org/t/616331/o2-amp-odac/2145#post_10350437 - which makes the modded o2's slew above your referenced baseline and just below that of the se-se wire).  Seems to sound slightly better to me than stock, although it very well could just be confirmation bias, a result of lesser dc offset, whatever.  At the end of the day, for those of us with more science interest than ability, it is really hard to know what to believe about this hobby, manufacturer descriptions & specs, and the aspects of design that really matter most.
post-11720029
Post #6,060 of 6,423
Sapientiam
That's my point - when presented with an FFT as a graph (rather than as a histogram) where is the information about the record length and the sample rate employed (not to mention the number of averages performed)? Some presentations do give some of that information, few give all of it. Without that data its not possible to 'count the bins'. In a time domain graph (say a scope plot) its normal to see both axes labelled (V, t).
I'm not out to descredit the FFT as a valuable tool here - I agree its useful and powerful. More to point out that a large number of users of it don't thoroughly understand it when employing it.
