Thoughts on a bunch of DACs (and why delta-sigma kinda sucks, just to get you to think about stuff)
post-11510934
Post #4,081 of 6,423
immersifi
Ann Arbor, MI. USA
Ann Arbor, MI. USA
Website
immersifirecordingservices.bandcamp.com
I agree with what you wrote but 'entirely subjective' might be a little strong. I (cautiously) think there may be some validity and statistical power in opinions found in this thread and in these forums generally. That is, these opinions' ability to determine a better DAC or whatever is better than one would obtain from a purely random selection.
It sure would be interesting to see some well done research looking into 'the audiophile experience' - but it's not a hot research topic AFAIK. There is a phenomenology here backed up by a loose, shared vocabulary among audiophiles that poses some interesting questions in terms of what objective correlates might be discoverable.
Indeed, our thread-starter purrin spent quite a lot of time in past years conducting CSD plots and looking (informally I think) at what correlates he and his fellow listeners could and could not establish. Purrin is most certainly not an outright subjectivist; rather he seems interested in exactly these broader questions. But also in enjoying the music
Again, I am not discounting opinions or attempting to denigrate them; everyone's opinion and preference counts (or should). I am however attempting to make a distinction between the results of well-designed tests conducted in an controlled fashion and opinion. Again, when differences are clear (and I'll concede that's a relative term) then yes, such structured tests are overkill.
I can say that, having worked (since 1990) in signal processing, NVH, and sound quality, double-blind tests are what is used industry-wide (and not just in automotive, but pretty much everywhere) to perform anything from simple rank-order of preference (product "A" against "B", "C", "D" and so on) down to regression analyses to better understand which psychoacoustic metrics best correlate with listener preference of the sounds evaluated. This is done for everything from power tools, to door closures, to hair dryers, leaf-blowers, lawn mowers...pretty much everything. Sometimes the answer is pretty immediate and clear, and other times, it's inconclusive.
One other thing that's done in industry that's never really done in these threads (not specifically headfi.org but others as well) is that in product development circles, the sounds that are recorded for evaluation by jurors are played back at 1:1 loudness levels. Let that sink in for a minute... in other words, if (for example) a dishwasher produces 57.5 dB(L), then that sound and others to be presented are presented at their correct levels in the headphones (in this example, the dishwasher sound, when played back in the headphones will produce 57.5 dB(L) SPL).
This really does matter, because of the anything-but-linear nature of the Human hearing mechanism. So, by ensuring that sounds are played back at a 1:1 loudness level (whether in sone or decibel) a fair comparison between sounds can be made. Otherwise, if left uncontrolled, by raising the gain, you may hear certain things that would otherwise be masked when the sound is generated by (in this case) the dishwasher. Conversely, if one were to conduct such tests at a lower-than-actual playback level, there is a reasonable chance that one would miss certain attributes of the sound. I think it's clear that after spending time (and costs) in setting up the test etc.to have the validity compromised by evaluating the products at levels other than their actual levels could be 'problematic'.
This should sort of make sense to anyone reading this even if they are not acquainted with the Human hearing mechanism's workings. That is, who among us hasn't noticed that what we perceive as well as emote can be dramatically affected by the level at which we choose to evaluate the sound (or song), or even simply listen to a track for pure enjoyment? This is a pretty important aspect of hearing and one that seems to be seldom controlled in most of the listening evaluations most often discussed on the web.
The problem with calibrating the levels of music is, of course, the recordings are seldom if ever level-calibrated (it is possible to do...), so there is a lot of latitude resulting in terms of what levels can (and will) be chosen when attempting to make an unbiased comparison between sounds / products. Mind you, if the Human hearing mechanism were linear (and by linear I do not mean 'flat') then the level at which sounds were presented would matter not, but this is not the case.
It's for this reason that juried sound evaluation software packages allow a loop calibration to be performed thereby ensuring 1:1 playback of actual sound levels. But...don't take my word for it - check the Society of Automotive Engineers (S.A.E.) database as well as those of the Institute of The Institute of Noise Control Engineering (I.N.C.E.) as well as the Acoustical Society of America (A.S.A.) for published works on juried testing (basically, similar to ABX, but with a few more options). If you are interested in knowing more about listening tests, you can web-search for 'juried tests' and "Bradley-Terry" as a start, but if you likewise search the names "Otto", "Lake", "Blommer", "Crewe", and "Cerrato" you will find many published works on double-blind juries testing and the results. Interesting stuff.
Reactions: arnaud
post-11511119
Post #4,082 of 6,423
Stillhart
CanJam@RMAF 2015 Karting Champion
Las Vegas
Las Vegas
FYI, discussions on double blind testing outside of the sound science forum is a great way to get the thread locked and some bans handed out.  Second only to discussing cables.  Not threatening, just warning...Amos is not a gentle mod.
post-11511137
Post #4,083 of 6,423
immersifi
Ann Arbor, MI. USA
Ann Arbor, MI. USA
Website
Hmmm...I'm not sure why I should be banned for discussing something that's related to the subject. In no way did I denigrate anyone or their positions or opinions, nor did I say anything untoward about any or all of the products mentioned. In fact, if you look at my previous posts, I actually asked the question about whether the assertions made were opinion, or based on more rigorous methodologies (and I even thanked one Member for having clarified the issue).
Having said that, I hope that what I have written does not get me 'banned'. I like the discussions here, and so far, I've managed to meet some very cool people.
Mark (immersifi)
post-11511143
Post #4,084 of 6,423
Stillhart
Las Vegas
Las Vegas
Mark (immersifi)
No judgement implied, man.  I'm just letting you know how Amos works.
post-11511150
Post #4,085 of 6,423
Ableza
Valley of the Sun
Valley of the Sun
If people get banned for off topic discussion then half the participants in the Schiit threads should be gone. Including me.
post-11511156
Post #4,086 of 6,423
Stillhart
Las Vegas
Las Vegas
I named two very specific topics, not all off-topic discussion.
post-11511319
Post #4,087 of 6,423
purrin
aka Marvey, purr1n
Member of the Trade: Eddie Current
"Future-proof," yes...but that doesn't mean they'll go from S-D to R2R. Similarly, just because the Bifrost is upgradeable doesn't mean it'll ever become a Gungnir or Yggy. But yeah I'm definitely hoping the Gungnir gets an R2R upgrade. The Yggy is about double the limit of my price range.
I doubt a guy who wears a T-shirt "D-S, when music doesn't matter" would subject any of us to an "upgrade" from D-S to D-S. The Bifrost form-factor seems awfully limited on real-estate though.
I don't see the problem with just unplugging the DAC board and putting in a new improved one. Doesn't seem implausible that Gungnir or Bifrost Uber couldn't be easily upgradeable with their configurations.
Hahaha. One thing I noticed when I popped the hood for the Gen 2 USB upgrade was the amount of space available.
  No, I'm not suggesting that all tests should be done via ABX, I realize the logistics. I was asking more about the original assertion that something 'sounds bad' and whether that was opinion, or the result of well-controlled listening tests with many subjects.
Some of the early stuff was done blind, but informally. Later, we shared notes. The R2R revelations and rankings are mostly my own, although specific attributes are agreed upon with the same set of people I share notes with.
In the end, it's all subjective opinions. Just crap outta my ass, confirmation bias, placebo, et. al. Take it as you will. I take audio seriously, but I don't take myself seriously.
I conducted a formal blind test of two amps level matched to +/- 0.1db with a switch box. Never again will I do such a thing. Never again. Easier to talk about than to do.
post-11511360
Post #4,088 of 6,423
mikek200
Brooklyn,New York
Brooklyn,New York
Age
70
deleted
post-11511362
Post #4,089 of 6,423
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
I wonder if there's enough space to fit in some transformers for a balanced output...
post-11511408
Post #4,090 of 6,423
wink
His amps are made out of recycled beer cans
and his source from tomatos.
Or, a switch on the front.
Or, perhaps even, a sensor for a remote control...........
post-11511416
Post #4,091 of 6,423
Sapientiam
Listening isn't as black and white as being either 'based solely on opinion' or 'based on rigorous methodology'. There is middle ground between those two poles - that's falsifiable descriptions of what we hear. Smell is equally a purely subjective perception but qualitative descriptions in that sensory domain have turned out to be useful to developers of scents. Luca Turin has done some excellent work there and you can read about that in his and Chandler Burr's books.
post-11511422
Post #4,092 of 6,423
Stillhart
Las Vegas
Las Vegas
Random question:  I've been listening to the Adcom with a coax cable from the Gustard U12.  On a whim, I connected the AES/EBU connector (3-pin XLR) and swapped to that.  I could swear it opened up the congestion and SS just a tad.  Is that possible?  I might have to have my wife flip the switch for me so I don't know which is which...
post-11511463
Post #4,093 of 6,423
purrin
aka Marvey, purr1n
Audio is like food to me. Xiaolongbao at Din Tai Fung at the Glendale, California location is not as good as the xiaolongbao at the Din Tai Fung at the Xinyi Taipei location. I don't need to take a double-blind and/or ABX test to know this or tell other people this. If anyone has a problem with my assertion, they are free to conduct their own double-blind ABX taste test of the xiaolongbao at these locations.
post-11511468
Post #4,094 of 6,423
purrin
aka Marvey, purr1n
Yes.
AES3 sounded better from the OR5 into the Gen V than SPDIF. Further improvement: very short run of a twisted pair in CAT5 (effectively same characteristic impedance of AES cable). Good time to learn how to solder if you don't already know how. Can save lots of money, or have you end up melting a lot of things.
post-11511478
Post #4,095 of 6,423
Stillhart
Las Vegas
Las Vegas
Yes.
Yeah, I've made my own cables and put together a Project Solstice.  Are you suggesting I use CAT5 cable into 3-pin XLR for AES3 connection?
BTW, I'm pretty sure at this point that it opened the soundstage and lowered the noise floor a bit.  Not much, but enough to not go back to coax.
