thought on Logitech UE-6000, sound quality, compatible with blackberry .
Nov 17, 2013 at 8:02 PM Thread Starter Post #1 of 4
fireworks1
hey fellas, so i just went to Future shop today and i saw this model. i tried it for awhile and i was actually impressed of its sound
quality. also i think the prise was pretty cheap compare to its quality ($140)
it has a noise cancelling function which requires battery charging but i'm pretty sure you can still listen to music without using
it.
i own a blackberry bold which i think it gives better sound than ipods so.. will it work well with my bb?
thanks
Nov 17, 2013 at 10:33 PM Post #2 of 4
it.
thanks
The remote in the logitech UE6000 is for ipod/iphone/ipad, however in many cases with you use this remote with androids, BBs and others only works the center button (skip songs, pause, play). However if you can go to Future shop again and plug the headphones in your BB, do it.
PD: I totally disagree this sentence "i own a blackberry bold which i think it gives better sound than ipods"
