- Oct 3, 2016
Would these work well with Fiio M6?
You would most likely be able to drive them (volume) but you will have quite a bit of hiss, due to the 2 ohms of output impedance.Would these work well with Fiio M6?
are you saying 2 ohms OI is too high for voyager 3?You would most likely be able to drive them (volume) but you will have quite a bit of hiss, due to the 2 ohms of output impedance.
Yes, the fiio M11 has that and it hisses alot.are you saying 2 ohms OI is too high for voyager 3?
The BTR5 and the M11 seems to have the Same OI so they should hiss as much. Do you have any other BA only iem that you can compare to? It is when you compare the hiss from the V3 to any other BA only iem that you can really tell it has alot of hiss.Getting no significant hiss from my BTR5, don't know if there is a big difference between that and an M11?
Absolutely in love with mine, they have shoved my T4s and N3s into their boxes. Only thing I'm struggling somewhat with is finding tips that I'm able to use over a longer period, as the foam tips I have all seem to "warm up" my ear to uncomfortable levels. Anyone had similar experience with foams, and can recommend something else?
Thats the reasons.Unfortunately they're the only pure BA set I have, so I guess it would be hard for me to tell. I do have a spot of tinnitus though, so I guess my ears could be less disposed to pick up hiss as well.
When I plug them into my Presonus iTwo soundcard there is quite a bit of hiss, which I guess would be expected. Compared to that the BTR is silent.
Thats the reasons.
1. tinnitus
2. your soundcard seems to have 50 OI and your btr5 is 2 OI so the difference is huge
3. no other BA iems to compare to
Sorry, but output impedance (and lowering it) really has nothing to do with hiss.
In fact, increasing resistance on the output of an amp is sometimes used to control hiss. It does this by providing further attenuation of the overall amplifier gain by adding voltage drop through the resistor. Less gain usually means less noise and hiss.
It's true that if you increase the resistance, you may significantly increase the output impedance of the amplifier. If that happens, more effects will accrue than just removing the hiss. So, it's definitely a good idea to stay aware of both goals.
Here's a pretty good guide on using resistors on the output for attenuating amplifiers:
https://robrobinette.com/HeadphoneResistorNetworkCalculator.htm
