Dobrescu George
Reviewer: AudiophileHeaven
does opus#2 can use external DAC?
It can be used as an external DAC from a PC / MAC, and I ***think*** that it will be able to output USB data to a device in a future update, but I'm not sure if it is able to right now. Some apps might enable this, if you connect it to an external USB DAC via a USB OTG cable, but given its sound and general qualities, I think you were asking whether it works as an external DAC, the answer to which is yes
Can someone tell me how to get into android mode so I can download and install apps like spotify and tidal?
There isn't an Android mode.
You download the apps to your PC via APK Pure or APK Mirror or even Play Store by downloading the APK files, you copy them to the mSD card or the internal memory, then you go to settings -> streaming, click on the plus button and it will help you install (sideload) any apps you need. Streaming works flawlessly for me actually, just a few more steps to take
