Hey all
been a lurker in head-fi for almost two years now,
maybe this is my first post in head-fi and i just want to chime in this thread
had purchased my opus for about 2 months now, overall I'm satisfied with its sound quality and performance albeit there are bugs everywhere
my foremost concern about this player are:
- hiss when you start playing music, i think it's already told here , when you play music for the first time after long idle, there are significant time pause and you will start to hear the hiss (maybe the amp circuitry is starting) and then the music starts to play. if you pause it and play it again afterwards the there wont be any idle and the hiss is still there, but if you pause it for quite long time the hiss will be gone ( i assume the amp circuitry turned off again) and when you click play, it will take long idle like when you play it for the first time
- cell interference already told here too, not a big problem to me, still could get a proper fix in the next opus version with better body material?
- Line out where? optical out with what cable? i still confused on how to use the line out of opus , honestly there are no single menu to switch to line out. when i tried to connect it to external amp it doesn't automatically detect it and switch to line out mode either. the only choice is to max out the volume and still no line out notification being displayed. i assume that if we max out the volume it's still not bypassed directly from the DAC and still get amped in the opus internal.Means if you connect it to the external amp it will get double amped?
as for the optical out it is said that it was combined with the SE jack, but i haven't found the right cable to use it. any hint for the cable you are using for optical output ?
@twister6 ?
-NO USB DAC (yet?) for the love of God, i need this
-other than that is the firmware related bug and feature that i think still need a lot of fix
oh and one last thing i will be really pleased if we can get the active official support back here on head fi , how month has it been since the last reply from the official support? even fiio or LP have someone to actively response to the user question and complaints.
