thebit Opus#1 DAP from South Korea
Nov 7, 2017 at 6:25 PM Post #3,408 of 4,190
I honestly don't think so. I have metal version. I didn't do a direct comparison tbh.
Could be my memory is just bad. I do remember the build quality feels good when you touch the top of the player. That's most impressive part of metal to me. And it has like a dusk paint finish.
Nov 7, 2017 at 6:44 PM Post #3,409 of 4,190
Oh, also! I'm using thebit Opus #1 metal, in USB DAC mode to try to reliably tell difference to Lame VBR 256 to 16 bit FLAC file from 7digital. Bought 3 of Selena Quintanilla's albums.
I'm still failing some tests, it's also really tiring doing this LOL.
The best I've gotten tbh from her Amor Prohibido album. These tests blown my mind a lot. If I cannot reliably tell difference between 256 Lame VBR to FLAC. I'm very certain I will not be able to gain much by getting Opus #1S.
This DAP might be an endgame for me until it breaks and stops working.
foo_abx 2.0.4 report
foobar2000 v1.3.16
2017-11-07 15:16:47
File A: 06 Bidi Bidi Bom Bom 1994 Version.mp3
SHA1: 8b2b00c9c68029afca9b0a4fc68bd02bd77a267b
File B: 06. Bidi Bidi Bom Bom (1994 Version).flac
SHA1: f00b227d1de81eb7539605c4e9479a32a2574352
Output:
DS : Primary Sound Driver
Crossfading: NO
15:16:47 : Test started.
15:18:11 : 01/01
15:18:40 : 02/02
15:19:08 : 03/03
15:19:35 : 03/04
15:19:57 : 04/05
15:20:19 : 04/06
15:20:40 : 05/07
15:21:13 : 06/08
15:21:38 : 07/09
15:21:47 : 08/10
15:21:54 : 08/11
15:22:02 : 08/12
15:22:09 : 08/13
15:22:21 : 09/14
15:22:30 : 09/15
15:22:37 : 09/16
15:22:47 : 09/17
15:22:57 : 10/18
15:23:04 : 11/19
15:23:15 : 12/20
15:23:15 : Test finished.
Total: 12/20
Probability that you were guessing: 25.2%
-- signature --
6b79a0be048b70c3024fec9d9735da8834687eae
Nov 12, 2017 at 6:50 PM Post #3,413 of 4,190
Well, since I have Spotify Premium now I've decided I may want a DAP with that function so I bought a Pioneer XDP-300R, gonna compare them and see if it's worth the price. If so, then my #1 will be up for sale.
Nov 12, 2017 at 7:23 PM Post #3,414 of 4,190
Does anyone else's USB DAC mode bug out?
Whenever I exit the mode, I have to restart the player before the mode works again with my laptop
Opus is for portable use. My DAC/Amp is the Audio-GD NFB-28. If you're looking for a very simple, affordable DAC for your PC, try something like the AudioQuest Dragonfly Red.
Some DAPs handle USB DAC function without issue, but I find they just aren't suited to that use. It's far better to get a standalone device, preferably one without a battery or screen, so it will last longer.
Nov 16, 2017 at 10:12 AM Post #3,417 of 4,190
Nov 17, 2017 at 9:51 AM Post #3,418 of 4,190
And of course my Pioneer XDP-300R Used from B&H arrived DOA and won't charge. Found a Silver version new on Amazon for $100 less. Will be here tomorrow.
Will be interesting to see how the Sabra DAC varies from the Cirrus Logic
Nov 17, 2017 at 9:56 AM Post #3,419 of 4,190
The Pioneer/Onkyo were on my list of DAPs when I was looking to buy. The specs on them were very similar to my LG V10, so I decided to try something a little different and went with the Opus #1. Comparing the 2, I would say that the Opus is more neutral, a little drier sounding, and wider sounding. The LG is a bit fuller sounding with a very slight V shape.
Nov 17, 2017 at 11:08 AM Post #3,420 of 4,190
I use the LG V20 and in comparison with my Opus#1, the v20 sounds a bit brighter and has more body on the lower end. The v20's amp is also powerful enough to drive and make my AKG K7xx sound good even though it needs a better amp. I agree also that the Opus#1 sounds wider than the v10/20 (I tried both phones and they sound close). Opus#1 sounds balanced overall though some may find it lacking in lower end body but it sounds fine to me. I just compensate by hooking it with my amp like the iBasso PB3 or if not, I choose an IEM with plenty of lower end body.
