The Zishan dsd's corner
Discussion in 'Portable Source Gear' started by neog007, Nov 17, 2016.
Tags:
36 37 38 39 40 41 42 43 44 45
47 48 49 50 51 52 53 54 55 56
  1. Origen Ru
    Which of the two players sounds more detailed and body ?, the Zishan or the D200 ?,
    Even though the D200 does not have EQ sounds better than the Zishan?
  2. Origen Ru
    Can you change the two OPA 2134P for two MUSES 02?
  3. NNewman
    Hello.
    Please to everybody interested:
    When you ask about D200 or Zishan DAD please specify the exact version
    D200, d200 v4, d200+ or d200+ ak4497
    Zishan DAD has many upgrade variants up to version 11.
    All versions of this two great players sounds great but VERY different in levels and costs quite different.
    Otherwise your questions and our answers are REALLY useless.
    knudsen likes this.
  4. NNewman
    D200+ can use two Muses02, but I didn't try it. I'm looking forward to try LM6172 at first, then maybe LME49720HA...
  5. Origen Ru
    This D200 version
    https://es.aliexpress.com/item/Hot-...der-HIFI-MP3-Music-Player-PK/32820023546.html
    And this version Zishan DSD
    https://es.aliexpress.com/item/HIFI...32755615721.html?spm=a2g0s.8937460.0.0.dGqwWs
    This D200 version
  6. NNewman
    Thats d200+ version. Here I will prefer d200 without any doubt. It MUST have a switchable balanced / unbalanced powered out.
  7. Origen Ru
    The D200 player is compatible with 32-ohm headphones?
  8. JASru
    Hi folks,
    Is there any vendor on ebay or ali selling the upgraded version of zishan dsd with knob(ak95)?
    How is the build quality on modded ones? As I heard the stock build is really on par with major chineese brands, while mods - not so much.
  9. hqssui
    If you search for "Hifi Fever DSD" in ebay, you could see plenty of listing for Zishan DSD with AK4495SEQ.
    On Aliexpress, I know CKLewis store sells them and I got mine from him. Very good experience buying from them.
  10. endia
    finally i could manage to replace those stock re3 caps with audio notes;
    no more coldness or brightness, more neutral presentation with slightly thicker and natural notes while resolution increased..
    but need to burn in at least 150-200 hours for final thoughts..
    btw i'm using intersil ISL28227 as lpf which gives me most natural sound among others (opa2604, opa2107, lm49720 etc).
    hakuzen and nick n like this.
  11. macky112
    my Zishan DSD is on firmware G and I just tried my apple lossless file on it and cannot play
    kinda annoying that my Zishan Z1 can play and my Zishan DSD cannot >_<
  12. JASru
    Does Lewis have modded versions too? How long do you have yours? Any issues? I have wav and flac library(16&24bit, some .cue), should I have any issues? How is the bass on stock version? Punch is present?
  13. hqssui
    I am not sure if he sells modded versions. You could contact him via Aliexpress. I find him to be very reliable and communication was great as well. I have the volume pot -less version of the player with AK4490 DAC chip. My music collection primarily consists of 16 bit WAV/ 320 mp3 and have not encountered any issues so far. It has a great EQ system where it accepts cfg file in rockbox format. If you want to tweak the sound according to your liking, it's doable.
  14. JASru
    Can someone with 95-version(one with volume pot) share an opinion on how is the bass presentation? Is it traditional AK( not very punchy, with more mass than speed) or more like a focused punch (like many CS based daps have)?
  15. nick n
    Swapped out the overly smooth syrupy 2604 opamp for a JRC 4580DD. This'll be staying for a while just gorgeous all around so far
    Testing with the highly revealing JVC/Victor Studios HA-MX100-Z.
    Was going to mess with replacing those 2 caps but only had 470uf's that were too large in size.
    I really wanted to throw some Elna Cerafine in that spot but no such luck.
    With this 4580DD opamp in the LPF socket there is no need to do so it has kept somewhat of the Elna RE3 signature or whatever they are stock, but dealt perfectly with their edginess.
    =Unit here is the stock one but with the15V board/mod option.
    ***endia your picture there how are you managing to use that adapter board opamp? Is the height a little less than normal?
    Does it not bottom out on the top board ?
    I might see about replacing some pins on a couple adapter boarded opamps i have here to reduce the height. Maybe.
