The Zishan dsd's corner
Discussion in 'Portable Source Gear' started by neog007, Nov 17, 2016.
Tags:
34 35 36 37 38 39 40 41 42 43
45 46 47 48 49 50 51 52 53 54
  1. hqssui
    A quick question. I noticed in one of the screenshots that the lowest frequency band for Eq is 60Hz. When you use rockbox parametric eq files, will the device accept bands lower than 60?
    Thanks in advance.
  2. hakuzen
    Yes. You can set a low shelf filter, up to 8 peak filters, and a high shelf filter. You can select the frequency peak from 20Hz to 24kHz, and the Q, for each filter.
    hqssui likes this.
  3. hqssui
    This is great. Thanks a mil. I have placed an order for the model without volume wheel. Hope it uses the same firmware.
  4. hakuzen
    I guess the firmware of that version should be a bit different, because it uses digital volume instead of analog.
    Let's hope it still accepts rockbox's parametric eq files. Remember you'll have to use rockbox eq editor from another source, or a text editor to create the eq files.
    hqssui likes this.
  5. hqssui
    You are right. The firmware should be different. Another thing I noticed is that it uses AK4490 DAC instead of AK4495 which is in the Zishan DSD with volume knob. Probably because of that and no volume knob, it's slightly cheaper. Thanks for the rockbox tip. I have never done it before, need a bit of research.
  6. Asakist
    IMG_2947.JPG IMG_2948.JPG IMG_2952.JPG IMG_2955.jpg I got Smart D200+ AK4497EQ. Sadly, this is discontinued.
    Sound is awesome.
    Does anyone have this here?
    NNewman and pitsel like this.
  7. hqssui
    That looks very good. I didnt know this is discontinued.
    Edit - it looks like your's is a special edition, is'nt it? The ones listed in AE has AK4495EQ in them.
  8. Asakist
    Yes,this is a limited flagship model (Red body). I think normal version (Black and Gold body)is continuing. :)
    pitsel and hqssui like this.
  9. Asakist
    IMG_2954.JPG AK4497EQ is good :)
    pitsel likes this.
  10. endia
    anyone tried to mod zishan? i want to replace those elna re3s to silmic ii but same values will not fit there.. what is the minimum values for voltage and capacitance here?
    6.3V 330 uF silmics barely fit here but i'm not sure if it's voltage rating is enough or not even in signal path? thanks..
    pitsel likes this.
  11. Luan Dee
  12. Moonstar
    Can anyone share it's first impression about the D200+ :)
  13. buzzbuzz
    Second.
  14. macky112
  15. buzzbuzz
    Question to T.R.A.N.C.E., NNewman, Asakist, and other knowledgeable persons/owners.
    Would you be kind enough to comment of all the variants
    1) Zishan DSD no volume dial AK4490
    2) Zishan DSD the "standard" version AK4495
    3) D200 standard version
    4) D200 v4
    5) D200+ AK4495 and AK4497
    6) E200 (?) - not on the market.
    Pro and cons. Recommandation?
    It would be very helpful to have these info in one place for someone like me unable to make a decision.
    TIA
    NotKunvinced likes this.
