gazzington
Wow, my zishan dsd turned up. It sounds great. I have some very pricy daps and this is not left behind by a large margin at all. Paired it with some kz iems and it all costs less than £150 and sounds great
Where's a reliable place to buy a muses op amp from for my dsd?
Since the Balanced output op-amps drive the 2.5mm TRRS jack, and the input to the Single-Ended op-amp - the problem is likely to be at the 22-Ohm Balanced series resistors, or the 2.5mm TRRS output jack. Due to the effect on the Single-Ended Output, I would suspect the resistors.
Are there any other DSD owners that you know of, in the UK? If it's someone who is planning to modify theirs anyway, maybe you could swap units, at least for them to check / repair the most likely problem areas. If that's it, then they could continue modifying the one that was yours, and you'd have a good stock model.
I Wanted to get Zishan DSD (AK4497) to use solely as a DAC/AMP with my computer and headphones.
I've read many places about how good the 4497-DAC chip sounds, but just wondering if I the Fiio K5 PRO(AK4493) might be less hassle.
Anyone know is there any other moderately priced DAC/AMP's that use the AK4497EQ ?
