The Zishan dsd's corner
post-15216628
Post #2,476 of 2,626
citral23
France
France
There are consistent reports about the screen of T1 being extremely outdated and a bummer to use (resistive), some reports about screen not responding or outright broken, pressing it admittedly "too hard" (shouldn't happen tho, ideally). Pretty much everyone agrees that the firmware is horrible, and that only the sound of this device makes it worthwhile, everything else sucks. Personally, I'd take a DSD pro (which I already own) any day over the T1, it has its quirks, but it's robust at least. I've given up on the idea of getting a T1 with all the meh to bad reports, and just purchased a Cayin N3 instead as a pocketable, more versatile and IEMs friendly device than the DSD, now that it sells for 123€ on Ali it's hard to beat imo (was more debatable when it was selling for 160-170).
T1 with the same AK4490, but inferior implementation imo (Cayin has < 1ohm output Z and really good lpf and amp section) sells for around 60€ but if the screen or USB-C ports give up within 2 weeks it's wasted money. Cayin is a mature product with reliable dac function, line out, remote control from smartphone etc. etc.
post-15222934
Post #2,477 of 2,626
Draknodd
Anyone knows at what voltage opamps are fed?
Reactions: DBaldock9
post-15222992
Post #2,479 of 2,626
Draknodd
+/- 9volts
Thanks then ... correct me If i'm wrong:
ak4497 outputs 2.8v pp, so 1.4v rms.
If I put ad8620 to gain = 3 I would have 4.2v
then 2x lme 49600 as current buffers
then 2.5socket.
Could it work ?
post-15223479
Post #2,480 of 2,626
therealbene
then 2.5socket.
Could it work ?
I think it's not that way. AK4497 is current output, where the Vrms is created in I/V stage. On LPF stage, you can adjust gain before being fed to your added current buffer, which might be possible assuming you can fit it inside the player.
post-15223816
Post #2,481 of 2,626
Draknodd
Ak4490 Is current output, ak4497 Is voltage output, no I/V stage only LPF in zishan
post-15228597
Post #2,482 of 2,626
gazzington
Wales
Wales
I notice on a group on Facebook that people make huge mods to these daps from op amps to see through body etc. Where do they get these see through body parts from?
post-15228699
Post #2,483 of 2,626
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
post-15228709
Post #2,484 of 2,626
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
Many craft stores have acrylic plastic, in multiple colors, and the clear glue to attach pieces together.
I'm not sure what technique they're using for making smooth, straight bends in the plastic.
post-15228773
Post #2,485 of 2,626
Draknodd
Just realized that your math might be off.
From - https://www.allaboutcircuits.com/tools/rms-voltage-calculator/ - I see that 2.8V (p-p) = 1.9798V (RMS)
Rookie mistake, thanks.
Still better, I've checked a similar mod with lme49600 on the SE output. With +-9 v at max volume there's clipping. Raising to +-12 Is easy (just change a resistor and the 10v rated caps), the step up Is a mp1542d so It should not be a bottleneck.
The mod is pretty easy but atm my main concern Is to find a comfortable Place where to take lpf signals. Taking the signal at output resistor could be and idea but I would need very small cables and to be very precise. This mod won't need a custom pcb at all
post-15228908
Post #2,486 of 2,626
Themilkman46290
Earth
Earth
The smooth strait bends on plastic are made using a bender, if your good at making things it can be home made, a power supply (9v) and a hight temp wire held at 2 points with good tension with a piano hinge on a wood table with a piece of wood on the end for the folding, you let it warm and slightly melt the plastic and use the hinge to do the work
post-15228947
Post #2,487 of 2,626
Themilkman46290
Earth
Earth
Thin metal like aluminium is good, in leather makes it feel nice, adds grip and won't Crack IMG_20191006_004405.jpg
post-15229327
Post #2,488 of 2,626
Merlin-PT
Reactions: Themilkman46290
post-15229721
Post #2,489 of 2,626
Draknodd
@Draknodd
I think you need 4 buffers for the balanced output, there are 4 signals to buffer L+L-R+R-.
If I understood it right, here @Ivan TT said he used 2 dual channel opamps configured has buffers for the BO:
https://www.head-fi.org/threads/the-zishan-dsds-corner.826185/page-98#post-14703801
That looks like another option.
I was thinking about this yesterday night: I thought "wait, lme49600 is 5 pin how the f is it possible to use only 2 of them". A solution could be 2x ad8397 with gain =1, they can output 310mA so they should be perfect as buffer
post-15229770
Post #2,490 of 2,626
Merlin-PT
Google if ad8397 is unity gain stable (gain=1), I've read it can oscillate, if so it's not a good candidate for buffer, but I never tried it.
