It is correct since the player “sees” impedance of the earphones when it is powered.
But I would not do it.
Hmm, why not? I guess because they are for protection right? If I change them for a very low value, let's say 1ohm, I assume it's almost the same as removing them completely?It is correct since the player “sees” impedance of the earphones when it is powered.
There’s at least two good reasons for output protection resistors being there:Hmm, why not? I guess because they are for protection right? If I change them for a very low value, let's say 1ohm, I assume it's almost the same as removing them completely?
Damn, thanks a lot. Then I am screwed. I really wanted this dap, but I already have 1 Multi-BA pair, and I am building another single BA earphone. And I surely cannot perform your mods with all this extra jumper wires, and small scale soldering, as I have neither the skills, nor the equipment and time. Also the 4495 is quite pricey, 140€, when I can get the 4497 for 90€. I guess I need to look somewhere else. Thanks again for the help!There’s at least two good reasons for output protection resistors being there:
They protect the output stage from short-circuit, which happens every time one plugs headphones in... or turns Zishan on as output relay shorts outputs to ground during time-delay period (few seconds until it toggles with audible click). Unless the output stage circuit is guaranteed to handle this condition and not to fry (one of the reasons I have OPA1622, indefinite short circuit time)
Headphones and cable appear as a capacitive load to the output stage, not many opamps can handle it well without going into self-oscillation (that you will not hear, but feel as things get hot!), no one really knows if this discrete output stage is prone to this or not.
So removing output protection resistors should be done at ones own risk and ideally taking into account (possible) consequences, again OPA1622 are there in my mod for more than one good reason.
Hope it helps.
Well, you can always give it a go and see what happens, my post above covers the theoretical assumptions, which are not always proved correct in practice.Damn, thanks a lot. Then I am screwed. I really wanted this dap, but I already have 1 Multi-BA pair, and I am building another single BA earphone. And I surely cannot perform your mods with all this extra jumper wires, and small scale soldering, as I have neither the skills, nor the equipment and time. Also the 4495 is quite pricey, 140€, when I can get the 4497 for 90€. I guess I need to look somewhere else. Thanks again for the help!
Nah, unfortunately I cannot afford such an experiment. So I will try to find something more suitable. I'll PM you about the IEM.Well, you can always give it a go and see what happens, my post above covers the theoretical assumptions, which are not always proved correct in practice.
What kind single BA you are building, if you don’t mind me asking? PM or post in the IEM thread
One of the reasons I wanted the Zishan, was the Balanced port. I wanted a source with balanced output, to give it a try. Also the 4490 model is less popular, and with less mods available. And I tried using the Russian forum, but it kinda didn't work for me. It's not very practical, if you want something more technical. It is slightly more expensive too, not by much, but it has an inferior dac chip.Well, I am not sure because I can't check, don't have a oscilloscope, but my ak4490 dsd has no problems with ba drivers, i am sure if to check player.ru someone there has the measurements, but as far as I can tell it has low impedance and the price is lower
Well i can say that hd600,hd650,dt770 pro 250 ohm, and akg k701 are the best i heard as far as fullsize and seahf f400s, k's samsara, ty hi-z hp150ts, toneking to200,to400,and if you want budget buds nicehck eb200, monk light spc 120ohmwhat’s best high earphone impedance for 4497 to be exact ?
100 ohms ?
I believe the function of the socketed opamps is a substractor, it substrats two signals (positive and negative) and this produces gain increase of x2, but the difference gets attenuated, thus improving signal to noise ratio. It also acts as an extra pole in terms of LPF filtering due to 1nf caps, to reduce delta-sigma modulator noise even further (as the cutoff frequency is way outside of the audio passband even at higher sampling frequencies.The non-inverting operational amplifier gain amplifies the sound.
Since tgecresistors are of the same value (1k), it has gain of 1, so any opamps used in dip8 socket should be unity gain stable (eg 627, but not 637 which may still work due to caps in the fb loop).
Just my two cents worth.
