The Xonar Essence STX Q/A, tweaking, impressions thread
Discussion in 'Computer Audio' started by telix, Apr 28, 2009.
1 2 3 4 5 6 7 8 9
11 12 13 14 15 16 17 18 19 20
  1. leeperry
    ok I've received my dummy TO99 + DIP8 holder, I just would like to know if G-Con fried his card [​IMG]
  2. leeperry
    [​IMG]
    [​IMG]
    it's very easy to trim/bend, I'd have done it right away...but G-Con put me off [​IMG]
    I'm sure the shield would even close(w/ some electrician tape on the cap) [​IMG]
  3. Bojamijams
    Originally Posted by Shahrose /img/forum/go_quote.gif
    Also, connecting a true headphone amp to the line-out or headphone out (even with the high gain setting) improves the sound quality noticeably. It does atleast in my case. I use the STX amped output in high gain mode (not low or extra high...they doesn't sound as good) fed into the M^3 and it is a combination I'm so happy with, that I don't think I'll be upgrading my headphone setup for a while.
    I'm using the STX -> M3 as well though, through the line out. It seems you're using the headphone out to feet it into the M3... with I guess some kind of a 1/4 -> RCA splitter? If so.. why not just straight line-out?
  4. fzman Contributor
    here's a drawing from the data sheet - which i believe shows it from the bottom lme49713.jpg and one from the top lme49713top.jpg
    this should allow you to bend them correctly. i've done about 12 of these between 49713s, 49710s, and 49720s, so i am pretty sure i know how to do it.
    they benefit from a slight trim of lead lengths, and you have to push them in so they make good contact, but without shorting them to the can itself. as i have mentioned before, doing a dry-run with a spare ic socket helps, and the pins will hold their "molded" shape after they've been socketed for a day. you can also get out the dmm, and check for continuity between the pins and the can body to make sure they are not shorting. put an insulator on the shield, not the ic, and you should be fine.
    hope that helps a bit more
  5. dex85
    does anybody know what is the best place to buy op-amps in europe? my local shops ask €25 for shipping from usa which is 2x more than op-amps i want. so any shops in europe that have op-amps actually in stock and don't overcharge on shipping?
  6. leeperry
    it was actually a lot easier to insert them in the STX holders than in the dummy one [​IMG]
    sound seems more bassy, but still very clear upper spectrum...less "thin", more "weight"...hope it won't change in the next burn-in days, coz I always had the feeling that the DIP8 4562/49720 would "lose" bass after break-in [​IMG]
    PS: the trebles are definitely even cleaner [​IMG]
    BTW, fzman, you didn't answer me about the STX+49720HA...does it hold to other <$300 external DAC's on top gear? like the HD800 [​IMG]
    ask National for samples [​IMG]
  7. ROBSCIX
    You can try Digi-Key, they are have a large selection and outlets in Europe.
    They should be OK for shipping.
  8. leeperry
    [​IMG]
  9. Bojamijams
    and the EMI cover still fits?
  10. gurubhai
    loving the 2 X LM49720 in I/V converter sockets.
    perfect match for my denons.
    treble has become much clearer & better controlled.
    Bass is reduced a bit in quantity but is tighter & punchier than before & overall bass is more impactful than before.
    pushed my HP upgrade for later [​IMG]
    ordered for 49720HA as well but am in no hurry to try them.
  11. leeperry
    well the SS has also become even wider, if that was even possible [​IMG]
    yes, the shield DOES fit [​IMG]
  12. dex85
    thanks guys, i emailed the Digi-Key. hopefully they will ship them over here [​IMG]
  13. chinesekiwi
    Make that three in the STX -> M3 club [​IMG] [​IMG]
    I'm feeding through the lineout as well and I found better SQ that way tbh + that I can hook up my AD700 to the headphone out so I can use Dolby Headphone while gaming [​IMG]. I have to put the volume to 1 (yes 1!) for the AD700's lol. Even then it's sometimes too loud thus I have to change the game volume in game.
  14. G-Con
    leeperry: Haha, perhaps I should have been clear that my card was definately not fried by my attempts. I did only try the one time to get 49270 working, I didn't attempt to reseat them. I'm going to give it another go after work today. I think I have to bend the pins a bit better, make them straighter and more vertical like DIP8 pins.
  15. ROBSCIX
    They should as they have outlets in Europe IIRC.
1 2 3 4 5 6 7 8 9
