Conan1974
HiSomething new arrived, AUNE SR7000. I had a short session of the DAP, and I like what I hear. Will try some more later on the desktop stack, but it's quite impressive how open the stage is to be closed back. Clean and balanced sound, nothing that sounds offensive or lacking.
Update after some hours:
It is easy enough to drive so you can use your DAP and Dongle and get good sound, it also scales if you give it more power from desktop gear. Good build quality, and okay stock cables (balanced 4.4 and 3.5mm) also a nice storage case. Very good comfort and not heavy, nice depth with angled driver (personal problem of ears touching the driver enclosure on most headphones).
The tuning is neutral warm, very balanced without being peaky or offensive. If anything a little safe up top, but still good extension to sound clear and open. Bass is punchy and goes deep, no bleed that muddy up the midrange. This is perhaps the most balanced closed back I have used, while also having enough warmth to be enjoyable. Maybe the most impressive is the soundstage, much more open than most closed back models.
It looks good, indeed. Did visit the Aune.com page. It is really nice, the specs are not bad as well.
How is the quality of the headphone, i mean how is it build?
How much space is there, for the ears? Like Hifiman HE1000 v2 stealth, Arya Organic or more like Focal Celestee?
I know You do not have them, but maybe You had a pleasure. This ones are the ones i know.
Thanks in advance for the info.
