kawaivpc1
- Apr 9, 2014
The ultimate DAP! 550GB storage, 10,000mAh battery, features of Note 4, 32bit 382kHz / DSD, Wi-fi support!
This is how you can build a dream DAP based on Samsung Note 4!
TOOLS NEEDED:
Samsung Note 4 Snapdragon Variant(Note 4, S4, and S5 have the best compatibility with portable USB DACs. It can run them without an external battery or a Y cable!) - Only snapdragon version can read 512 cards!
http://www.bestbuy.com/site/samsung-galaxy-note-4-4g-cell-phone-charcoal-black-at-t/8766009.p
10,000 mAh battery case for Note 4 - $60
http://www.amazon.com/gp/product/B00Q7C6FTA/
SanDisk 512GB SD card - $599 (or a 256GB SD card - $100)
http://www.adorama.com/IDSDSDXPA512.html
http://www.amazon.com/PNY-Elite-Performance-256GB-Speed/dp/B00FF90EZM/ref=sr_1_1?ie=UTF8&qid=1420454960&sr=8-1&keywords=pny+256gb+sd+card
MicroSD to SD adapter - $10
http://linitx.com/product/ablytech-sdmicro-to-sd-card-adapter/11922
USB Audio Player Pro or Hiby Music Player (Free) - $10
https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro&hl=en
https://play.google.com/store/apps/details?id=com.hiby.music
A portable DAC such as Geek Out 1000 -$299
http://www.amazon.com/Geek-Out-1000-Headphone-Amplifier/dp/B00JD0CV3M
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note4:
stock Samsung Galaxy Note4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/gnmvuf
Recommended: Geek Out 1000, Meridian Explorer 2, Sony PHA-3, Oppo HA-2 (coming soon), Calyx F (coming soon), Chord Hugo, iBasso D55.
Geek Out works with Samsung Note series without an external battery or a Y cable!
http://www.head-fi.org/t/711267/light-harmonic-geek-out-em-1000-impressions-thread/480
Samsung S4 + Meridian Explorer 1 DAC (works!!)
(Optional) If you need more than 512GB, you can try to use a 2TB Wi-Fi HDD. They work with cellphones.
http://www.amazon.com/Seagate-Wireless-Portable-Built--STCK1000100/dp/B00AQRUW4Q/ref=sr_1_3?ie=UTF8&qid=1420453699&sr=8-3&keywords=wireless+hdd+2tb+seagate
http://www.amazon.com/Passport-Wireless-Mobile-Storage-WDBDAF0020BBK-NESN/dp/B00M9B4482/ref=sr_1_1?ie=UTF8&qid=1420453724&sr=8-1&keywords=Western+digital+2tb+wireless
You can simply put a 512GB SD card with an adapter inside the battery case of Note 4.
After that, you can start using USB Audio Player Pro or Hiby Music app to play music through a portable DAC!
This setup proved to be working fine and it will provide you with 10,000 mAh battery, 512GB + 32GB of storage, sound quality of a chosen portable DAC, and UI of Note 4!
http://forum.xda-developers.com/note-4/general/half-terabyte-phone-tank-phone-550gb-t2987826
This is much better and cheaper than AK240. It will provide you with more than 24 hours of playback!
No external battery or Y cable is needed!
There's no UI bug, size issue, SD card loading time issue, battery life issue, and sound quality issue.
Geek Out 1000 sounds nearly as good as AK240! http://www.head-fi.org/t/746183/geek-out-1000-vs-ak240
This set up works fine for Galaxy S4 too: http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/5865#post_11120441
FYI, Oppo HA-2 and Calyx F 32bit 382kHz portable DACs are coming within the next three months! http://audio-head.com/the-new-oppo-pm-3-and-ha-2-rmaf-2014/
TOOLS NEEDED:
