The Takstar, Technical Pro, Gemini Greathon, CyberX, Qpad Thread
Feb 18, 2016 at 4:04 PM Post #3,961 of 4,675
RedHarlow
I don't find the soundstage on the HI2050 significantly better than that on the Pro80. In my opinion the HI2050 has a poor soundstage for an open can and the Pro80's got a very good one for a closed can but obviously YMMV....
I got both headphones and the soundstage on the pro 80 isn't as good as the soundstage on the HI 2050's. But overall it's personal preference.
Feb 18, 2016 at 4:09 PM Post #3,962 of 4,675
Norway
Of course I've got both as well, otherwise I'd never make such a comment. I use them both with HM5 pads though.
Feb 18, 2016 at 8:02 PM Post #3,964 of 4,675
el boricua
Yeah but is it the newer version? I wouldn't buy the Hyper X cloud or the Takstar Pro 80. They suck for gaming because the soundstage is terrible.
If you want the Takstar Hi 2050 with a mic go and get the Qpad QH-85. The mic just isn't that good.
Cheap usb sound card Takstar Hi 2050 combined with the Sony ECMCS3 is the better and cheaper solution.
i just know they look the same as the one in amazon for $60
Feb 25, 2016 at 6:56 PM Post #3,969 of 4,675
Zenbun
Anyone have any recommended sellers from aliexpress (or similar sites) for the Pro 80?
I found these:
http://www.aliexpress.com/store/product/Takstar-Pro-80-Prefect-HI-FI-Headset-Pro-80-Professional-Monitor-Headphones-Audio-DJ-Stereo-Monitoring/816277_2043150859.html
http://www.aliexpress.com/item/Original-Takstar-Pro80-Pro-80-studio-headphone-HIFI-noise-isolating-headphones-studio-Professional-monitoring-headset-head/32529730288.html
Is there even a risk for fakes?
I assume the not "updated" version is preferable?
Feb 25, 2016 at 9:20 PM Post #3,970 of 4,675
el boricua
i bought my 2050's from Arial XU in aliexpress and i recommend them.
Feb 26, 2016 at 1:16 AM Post #3,971 of 4,675
Noldir
No fakes have been spotted in the wild as far as I can tell. What do you mean by updated version?
Mar 1, 2016 at 12:23 PM Post #3,974 of 4,675
linkin360
I've been using the Gemini HSR-1000 with a PCI audio card with integrated headphone amp (Asus Xonar DG) and I think i was only experiencing half the potential of these headphones before that.
I had used the headphones with a Galaxy S4, Fiio X1 and a samsung laptop. Of course, the best quality came from the Fiio and I thought that was about 100% of the max performance for these: \insert "never have I been so wrong" meme.
The volume and clarity I get from the new combo is great, I'm far from experienced in audio evaluation but what I hear is a lot more volume but completely under control, defined bass and no harsh highs or sibilance. I've listened to metal, R&B and Hip-Hop, mainly, a few symphonic albums and a couple dubstep songs i don't completely hate to see the amount of bass possible, everything has sounded better than expected. Now I kind of feel like "I need" a portable amp to use in combination with the Fiio, I'm currently convincing my wife about that, I've found it's a little easier to achieve when she can comprehend the advantages of quality audio, for that I've given to her a nice sansa clip zip and some decent iems
Mar 1, 2016 at 1:04 PM Post #3,975 of 4,675
anticute
Clip+ and Topping NX1 worked quite well for me with the Pro80. Pretty nice combo for a rather small price :)
