LaughMoreDaily
Has anyone compared the Benjie T6 to the Zishan/Walnut players? Sorry, if I asked before...
My benjie fw v1.08beta ,how to patch ? Please helpWhat version of firmware is on your Benjie? If it's 1.07 or 1.08 you need a patched version of rocker 1.2.
Try the file here: https://ufile.io/7wxdyMy benjie fw v1.08beta ,how to patch ? Please help
Its working ,and now my benjie t6 is v1.2 Model Rocker. Thanks!
how to install it? can it run on rocker 1.2 ??Go here for some theme files: themes.rockbox.org/index.php?target=gogearsa9200
The best ones I found are Smooth2 and Winter Horizon.
I assume you installed rockbox already, if you haven't go to my previous reply and grab the latest build then drop the .rockbox folder into your sd-card and select it on system boot.
Themes will be .rockbox folder, just drop them in there then go to settings and change the theme.
I'd love switching to Rockbox, but really need functioning bluetooth. Any word on it?
is there a difference if we install Rockbox?Even if you switch to Rockbox, you still have access to the original Rocker firmware every time you boot up. So you can use either firmware at any time.
And check this thread for information on Bluetooth functionality being added to Rockbox. http://forums.rockbox.org/index.php/topic,51653.0.html Sounds like it's possible, and there's lots of requests for it, it just hasn't been implemented yet.
