The Review Tour of FiiO Q1 Mark II Apple MFi Certified DAC & Amp Starts Right Now.
Discussion in 'Portable Headphone Amps' started by FiiO, Jul 17, 2017.
1 2 3 4 5 6 7 8 9
11 12 13
  1. Nymphonomaniac
    Intersting, can you link where you find this info.This perhaps explain some impressions I have with Senfer PT15 earbuds that sound way better with balanced output, and volume can go higher to, must try it more tough, but if its true that like 3 times more power? :confused:
  2. VDRIVN
    @Nymphonomaniac exactly, I believe 75mW is a little bit underwhelming for any cans, be it IEM or larger cans.
    The info is found on the official website, each output has a section with the stated values: http://www.fiio.net/en/products/76/parameters
    I'm trying to drive various over-ear headphones, mostly with 40mm drivers and ~40+ ohm impedance. From previous experience, sadly I cannot find the 75mW output satisfying, and I'm really considering this device in hopes of having the chance to get higher output for my cans. Buying an extra AMP and amplifying the line-out signal would defeat the purpose of having an all-in-one device that can do everything, much like the e17k does.
    Thank you.
  3. Nymphonomaniac
    Yes, what you write its true, it look like to have beein thinked for balanced output power finally, this is why I just use it with IEM that will benifit from extra Bass gain. Copy paste it here so everybody know what the specs are without having to search too much.
    Must admit im confuse to how to use headphones with balanced....think I will have to search for 3.5 to 2.5 balanced adaptor now.
    Headphone out specifications (3.5mm headphone out jack)
    Output Power 1 ≥112 mW(16Ω / THD+N<1%) Output Impedance <1.2Ω (32Ω loaded)
    Output Power 2 ≥75mW(32Ω /THD+N<1%) Channel Separation ≥79 dB (1 kHz,AUX IN)
    Output Power 3 ≥11 mW(300Ω / THD+N<1%) THD+N <0.002% (1 kHz, AUX IN)
    <0.003% (1 kHz, USB IN)
    Frequency Response 5 Hz~55 kHz(-3dB) Peak Output Voltage >4.4 Vp-p
    SNR ≥116 dB (A-weighted, AUX IN)
    ≥109 dB (A-weighted, USB IN) Max. Output Current 150mA (For reference)
    Gain -2.5dB (G=L)
    3.2dB (G=H) Max. Input Level 3.4V
    Balanced headphone out specifications (2.5mm TRRS headphone out jack)
    Output Power 1 ≥240 mW(16Ω / THD+N<1%) Output Impedance <2Ω (32Ω loaded)
    Output Power 2 ≥220 mW(32Ω /THD+N<1%) Channel Separation ≥93 dB (1 kHz,AUX IN)
    Output Power 3 ≥45 mW(300Ω / THD+N<1%) THD+N <0.002% (1 kHz, AUX IN)
    ≤ 0.003% (1 kHz, USB IN)
    Frequency Response 6 Hz~80kHz(-3dB) Peak Output Voltage >7.4 Vp-p
    SNR ≥115 dB (A-weighted, AUX IN)
    ≥109 dB (A-weighted, USB IN) Max. Output Current 150 mA (For reference)
    Gain 3.2dB (G=L)
    9.1dB (G=H) Max. Input Level 3.4V
  4. FastAndClean
    how is the dac on that ting, i dont care about the amp?
  5. Nymphonomaniac
    Pretty pretty nice if you ask me, it use Xmos as usb receiver and very enojoyable and clean sounding AK4452 DAC. Can play anything UP to 384Khz and DSD support too.
    Don't need any driver on my WIndow 10 as well as on my Samsung J3, plug and play and enjoy.
    Sound is quite clean and neutral with good dynamic, details and extension, not harsh, little little dark (in a good way), and if you want it more bassy the Bass gainis very well made and give some warmnest and body to whole sound to the cost of deepnest of imaging, wich is very good without Bass gain. I'm sincerly impress by this DAC performance, and with balanced sound is even more clean and separation even more better. If you plan it to use it with headphones, it should not be more than 32Ohm, if sound pressure is hign 64Ohm could do to.
  6. FastAndClean
    i want to use it as a dac only with my laptop, windows 8, now i am using dragonfly 1.2 and i want upgrade but not to expensive
  7. Nymphonomaniac
    Hum. Did not try this one, just check the DAC and sabre ESS9010 sure have a different soundsignature, surely a little colder and analytical but can't say either....what type of sound do you search, and what your iem or headphones you will use?
    Listen right now with very easy to drive PMV A01 MK2 and its very very enjoyable,especially the fact that bass gain help with the bass it was lacking, but bass gain do not muffled mids (wich is somewhat a miracle). This IEM will tell me if the Fiio Q1 MK2 make any hiss cause there not forgiving, and its complete blackground.
  8. FastAndClean
    i use Hifiman HE500 and magni 2 amp, the sound is fine but the dsp playback on the Fiio is appealing, i have a couple of dsp albums on the hard drive
  9. Nymphonomaniac
    :astonished::astonished::astonished::astonished:
    OKAY.
    Ya got serious gear bro.
    And a AMP. So not bothering about amping of Q1....
    When I use it with my Ibasso BOA amp it sound even better and sound open with great imaging and instrument separation. I really think its a good bet for DAC himself....especially if you plan to perhaps use it with a phono to, time to time...as it have a very nice balanced out with more power, its very interesting for that too, if you don't plan to use any of this options, i'm a little confuse to suggest it to you, but as said, for sound himself its excellent. I kind of prefer it to Ibasso DX90 dac that use dual ESS9018, cause it can be too razor sharp some time, and mids are better with the Q1, but I still adore the DX90.
  10. FastAndClean
    the magni 2 is not serious but the HE500 is very good indeed
  11. Brooko Contributor
    Please just post names of the headphones. 40mm driver means nothing. 40 ohm without knowing the sensitivity means nothing. I think you'll find that unless you're trying to drive exotic headphones with really low sensitivity, then the Q1ii will more than adequately power them - and your quest for more power is mis-guided.
  12. VDRIVN
    Fair points.
    I'm looking to drive primarily the MDR1ADAC which I use at work (I find the integrated dac/amp lacking volume, it's limited by European regulations), the sensitivity on these is 102 db/mw and impedance is 40 ohm @ 1khz. I'd also like to drive the DT770 250ohm I use at home but I know that might be a stretch @ 75mW.
    Also, the spec sheet of the MDR1ADAC states a Power Handling Capacity of 1500 mW (IEC), so 20 times the power Q1II outputs on the 3.5mm :) (not sure if this is confirmed or not, but I drove them with the Fiio A3 and they were not distorting even at max volume (the A3 is rated 270mW @ 32 ohm)
  13. Brooko Contributor
    Q1ii
    Max output on SE = 1.5v VRMS, 150 mA, around 60 mW into 40 ohms
    MDR1ADAC - 40ohm 102db:
    Loudness / Voltage Needed / Current Needed / Power Needed
    85 dB SPL 0.03 Vrms 0.75 mA 0.02 mW
    100 dB SPL 0.16 Vrms 4.0 mA 0.64 mW
    110 dB SPL 0.50 Vrms 12.5 mA 6.25 mW
    115 dB SPL 0.89 Vrms 22.25 mA 19.8 mW
    120 dB SPL 1.59 Vrms 39.75 mA 63.2 mW
    It will drive them beyond the pain barrier
    Q1ii
    Max output on SE = 1.5v VRMS, 150 mA, around 15 mW into 250 ohms
    DT770 - 250ohm 96db:
    85 dB SPL 0.14 Vrms 0.56 mA 0.08 mW
    100 dB SPL 0.79 Vrms 3.16 mA 2.50 mW
    110 dB SPL 2.51 Vrms 10.04 mA 25.20 mW
    115 dB SPL 4.46 Vrms 17.84 mA 79.57 mW
    120 dB SPL 7.93 Vrms 31.72 mA 251.54 mW
    Q1ii will get them beyond 100 dB SPL, so it depends on how loud you listen. I average 65-75 dB so it would power them with no issues. If you listen loud, you'll need a more powerful amp.
    Paul
    BTW - that spec of 1500 mW is theoretically how much power before you start melting the drivers. it has nothing to do with power required.
  14. Brooko Contributor
    Just another general thought. Most people on these boards seem to think their headphones require far more power than they actually do. Don't get sucked in. Crunch the numbers. Often you can spend a lot less than you really think you have to.
  15. WaffleBoy
    So to sum everything on this thread,
    If I have an iPhone 8, Should I have this FiiO?
1 2 3 4 5 6 7 8 9
11 12 13
