Xcalibur255
- Feb 4, 2008
Also, a quick update: I spent a fair amount of time re-listening to both the Triangle and the Motorola tubes. Ultimately I think I can stand by what I wrote originally, but there is definitely something interesting going on here. My concern is that I was mis-identifying one of them, given that the two tubes appear to have identical construction with only a minor difference in texture on the black coating of the anode plate being the differentiator. This would suggest that the Triangle is also a Tung-Sol and not a Sylvania, since the Motorola tubes actually have the Tung-Sol manufacturer ID code (322) and the plates and bottom mica match the VT-94 I'm inclined to trust that ID.
However, my listening impressions hold up. These tubes look the same but they do not sound the same. The differences are substantial. The Triangle is less resolving, more V-shaped in its tone profile, and less precise in its imaging. The Motorolas are just how I remember them from a week ago, though I felt this time they had a little more upper mid energy than I wanted. There could be any number of reasons for that, including some wild swings in barometric pressure here lately. My ears are sensitive to those and will feel plugged up for a couple of days when they happen and everything seems a little more tinny when they do.
The Triangles don't sound bad at all, the Motorolas are just better. They don't sound wildly different, but the Triangle matches the Sylvania sound profile better so I'm going to stick by what I wrote originally and leave the identification as is. If they really are Tung-Sol made then the implications here are interesting. This would mean the tube-to-tube variation on these could be very substantial, or that internal differences we cannot see such as grid wire tolerance and tension could be responsible for the difference and there is no way to know before buying.
