pravous
Finally found a matching Tung Sol 76. Construction and sound very close to the 37 but no background noise. The TS 6j5g/vt-94a has so far eluded me but if the sound is similar I can see why they are so highly spoken of.
Things are starting to get a bit crowded in the ol' Woo Audio WA5-LE...
My adapters finally arrived, and seem to be working just fine. Tubes are Zenith 6J5G. Looking forward to this new experiment!
Not sure -- my first jump into the 6J5's, I've still got some research to do.Zenith 6j5g are one of my guilty pleasures. I got my pair cheap and they are my default inputs in my Bottlehead crack in my shop. I believe they were manufactured by Sylvania and rebranded Zenith?
Snag any L63 / 6J5G from Langrex?Thanks! Looks like it's off to Langrex I go with what's left of my wallet...
Quite a few are, I would say the majority in the case of the coke bottle tubes, but not all. Some of them are Raytheons, and the late 30's Sylvania and Raytheon 6J5 tubes are pretty much on opposite ends of the spectrum from each other in terms of sound so it might be good to watch out for mis-matched pairs here. I've seen quite a few that are too, it's easy to tell by looking at the top mica support. The Raytheon are cross shaped and the Sylvania are rectangular with rounded ends and are held against the glass with a pair of thin steel tension wires.Zenith 6j5g are one of my guilty pleasures. I got my pair cheap and they are my default inputs in my Bottlehead crack in my shop. I believe they were manufactured by Sylvania and rebranded Zenith?
The left tube there, Crosley Ken Rad, is the first where I have seen the typical notches in the top mica. On all I have handled they are in the bottom mica. Interesting. Early Monday morning at the factory?Having some 6J5 Fun... Yes i realize the kenrads are not absolutely identical but i am using them as a pair none the less.
That was what I was asking, thank you.Perfectly safe to mix a 6J5WGT and a 6J5G together, they are electrically identical. It's not OK to run one 6J5 and one 6SN7 in the adapter though, just in case that's what you're asking here. The pin connections are different.
