The PANASONIC RP-HTF600-S headphones. More fun than the HD650?
Sep 20, 2014 at 10:30 AM Post #2,806 of 2,849
Sebastiene
I have the following setup.
LP-2020A+
3M 3.5mm Female Stereo Jack to 2 Male RCA Plugs Cable
Jack Plug To 2 x RCA Phono
DISCLAIMER: Audiologists (hearing doctors) and audiophiles might cringe at this. Doing what I just did may damage:
1) Your headphones ... or ...
2) Your hearing ... or ...
3) Both of the above.
Thanks to J. Alec West
The amp is rated at 20 watts per channel and comes with an AC adapter for in-home use. On the front panel, there's an on/off switch, a "tone" on/off button, treble control, bass control, and volume control. On the back panel, there is no headphone output. But (evil grin), there are wire-by-wire speaker outputs. I took the 3.5mm female to RCA stereo male cable and snipped off the RCA parts. I stripped back both right/left cables to expose the bare wires, hooking them up appropriately to the amp's speaker output. Also on the back panel, there's an 3.5mm female stereo input for stereo outputs after using went to lead mentioned above (better)from MP3 players (and, hehe, laptops). For that, I only needed the 6-foot male-to-male 3.5mm stereo cable.
I used lead mentioned above
The laptop audio cable is plugged in. VLC opened, half-volume (computer set at half-volume). I started playing the song  and, ever so slowly, cranked up the amp's volume.
YEE - HAH !!!!!!!!!
I only dared turn it up to one-third volume ... which, for this experiment, turned out to be the borderline between "safe concert level" and "ear bleeding level." 8) But, WOW, what crisp audio and fully enhanced bass. My headphones were loving it (me, too).
Of course (snicker), this was an "experiment." Results by others may vary.
I then went to srs labs sanddbox and fiddled
WOW
I believe I'd pay £100-£300 for this it only cost £40
Thanks head-fi
Oct 5, 2014 at 2:26 PM Post #2,807 of 2,849
daivatam
Hi!
I bought this headphones in europe with 70$.
They sound nice no complaint...but reading on this thread I took the advice to burn them in...for a better sound.
I let them yesterday some 5 hours with some random normal melody at medium volume and today for another 3-4 hours with an deep bass testing piece sound  at low volume.
Unfortunately when I put them on ...my left speaker was dead...after some knock with fingers on exterior was started again but after some other small knock to see what is happening was dead again and remaining dead for good. I notice that if i push on the headphones with my hand when they are over the ear ...from the dead speaker I hear the membrane moving and making crack noise and on the good one do not...
I am skeptic if the warranty will cover this and I am am upset just purchased this headphones and are not cheap at 70$.
So take care on burning in this...i think the quality of the speakers are not so good and they crack easily.
This is the melody that destroyed them.
http://www.youtube.com/watch?annotation_id=annotation_127981&feature=iv&src_vid=mlGk4QXl8_M&v=XNYyZfamkUs
Oct 6, 2014 at 1:55 AM Post #2,809 of 2,849
daivatam
This was my first though, that it is the wiring because the speaker started again after some knock.
I open it and check-ed the wiring and there are no problem.
I think that simply the membrane is out of place or the coil it is out.
Because the membrane of the damaged speaker is making crack-ing sound when I push the speaker over the year and the other one don't make that crack sound... tell me that it is out of place or just moving more easily of some sort of cause...
Nov 7, 2014 at 4:30 PM Post #2,812 of 2,849
azrussell132
As of today:  9 in stock and $32.70 each with free shipping.  Excellent deal.
Feb 14, 2015 at 10:20 PM Post #2,813 of 2,849
Deezbeats
I know this thread is old... but can someone help me out? The cables in the left driver became dislodged when taking apart the headphone, and now re soldering them back the left driver plays both the left and right audio channel. Does anyone remember where each wire goes?
Apr 14, 2015 at 7:47 PM Post #2,818 of 2,849
crash88
Agreed, it was the best upgrade I made on the phones. People say the sound is better with them but I really don't hear the difference. But the comfort was worth every cent. I use them on a daily basis at the office and still loving these cans!
Apr 25, 2015 at 6:02 AM Post #2,819 of 2,849
Mikegy
I found these Panasonics to have a warm sound that only improved with burn in.I know there is always debate on whether burn in is a legitimate concern or not. After receiving these headphones,I used my Samsung Note 3 adapt sound to equalize headphones. After approximately 40 hours of burn in, I went back under the exact same conditions with same humidity and temperature and ran the adapt sound again. the frequency curve showed boosted bass with a moderate midrange bump, and a Rolloff of high frequencies originally. The second running of the adapt sound found the mid range bump flattened with smoother and more extended high frequencies.I am well satisfied with these headphones and their value. They have a warm signature that has improved to an audible extent after leaving them play over several days. Bass is extended and bleed over into the midrange while present, never excessively compromised my listening enjoyment. Bass bleed over into the midrange suprised me by actually showing a decrease in level after the forty hours of play time.
