Thanks regardless for trying. I'm sure Twister had good intentions and I still got something valuable from his post. Likewise, thanks for the correction Toaster.
Would you guys say most 64 Audio IEM users have a pretty good DAP, or do most just plug into their phone?
Was always curious of this because it sounds pretty decent just off a phone from my experience.
Wait, "thanks regardless for trying" and "...had good intentions" ? Where did I fail, Frank?
You were confused about how LID tech works and I explained that it's not a magic bullet that going to make your smartphone or laptop or $99 dap sound exactly like $3.5k flagship
Considering most of the today's DAPs (used by audiophiles) have output impedance less than 1 ohm, and most of the professional gear (used by sound engineers and performing musicians) has higher output impedance, and smartphones and laptops are in a grey area - all this means that LID tech will insure that output impedance of the source doesn't have effect on the sound. The sound will be affected by all other components of the source design.
As I said before, A/U18t and Fourte didn't have LID because those are early models, and Bogdan (who is former 64audio CEO) confirmed that above. Fourte Noir didn't have LID and it was a refresh of Fourte, plus it looks like Noir is no longer available for sale on 64audio site (removed from listing). The latest announcement is A18S and "the A18s is designed off of 64 Audio’s existing 18-driver A18t platform, but is now applicable to demanding stage and studio environments" - meaning if they are adding LID it was done intentionally so that both audiophiles and studio musicians are not affected by low/high output impedance of their sources.
Again, I can't speak on 64audio behalf, but the explanation of "...they left the LID tech out of their TOTL offerings in order to give users the highest ability to modify the sound of their iems." makes no sense to me because A/U18t and Fourte were released before LID tech was introduced, and only showed up in later models of U12t/Trio/N8. LID "corrects" output impedance of the source, while majority of audiophile DAPs have low output impedance already, so I'm not sure how are you going to modify your sound, unless you are looking for high output impedance sources? Sure, you can find an old Hiby R6 or Tera Player, both of which have higher than 10 ohm output impedance, but it will only mess up your sound signature. Also, LID is not an option, so you can't compare, for example, U12t with and without LID to speak of its benefits or disadvantages since you can't do a side by side a/b comparison.
And as it was mentioned by others above, using your phone or a laptop will not ruin the sound, but it will scale down the technical performance of soundstage expansion, imaging, layering and separation of the sounds, and just overall resolution.
