- Oct 6, 2013
Diameter is identical. The length of the bore is slightly longer than the Fourte.
and just to add to Bogdan's reply, Fourte on the left and U18t on the right.
Mentor v3hello guys, I was wondering about the N8T if it is compatible with iPhone? I am looking for musical in-ear with a Thick vocal and bass (not revealing) for my mobile. I am not into DAPs neither DACs. I use A18t with pw audio 1960 ( 2 wires) cable which is perfect with classic music but not 100% satisfied when I play different genres. I am looking for something easy to drive and fun to listen. I'd appreciate your recommendations thanks.
Thanks, I have read a lot regarding Unique Melody I will check this oneMentor v3
thanks for the reply. Is it compatible with mobile? I am more into music apps like Tidal / streaming on youtube which makes the A18t not the best match. I actually use Se846 Shure most of the time and would love for something the could be an upgrade for the Se846. Do you think the A6t has could be an upgrade for the Se846? I listen to pop, electro, classic and acoustic.The N8 is a more dynamic and fun-sounding IEM, perfect for genres like pop, rock and EDM. If you’re looking for an IEM that’s warmer, softer and more euphonic than the A18 - but still in the same vein in terms of signature - the A6t with the M20 module is a great choice as well.
How long exactly sir
Stay updated on FIR Audio at their sponsor profile on Head-Fi.
Mentor v3 seems like a good match actually
Does it need an amp to drive it? or I can stick it directly to mobile?Considering your list of genres and the fact that you’re looking for an SE846 replacement, the N8 would be best for you, then. It has similar goals as the SE846 - in dynamic energy, resolution, bass performance - and completes them all in a significantly better way. I think you’ll really be happy with it.
I have doubts about the Mentor V3’s long-term performance. I think its boundless sense of energy can get fatiguing after some time. I’d personally take the N8 over it, but to each their own.
I will try the demo then. Thanks DeezelThe N8 should sound perfectly great out of a smartphone. An amp will certainly elevate its performance, but it won’t perform any worse than the A18t will out of your phone.
