The Official 64 Audio Thread | apex & tia Technologies
May 10, 2018 at 9:55 PM Post #4,186 of 23,417
WM1Z, just googled it...woah on the initial sticker shock. Also looks like it isn't compatible with Tidal so if that is my source for high-resolution audio files that would be problematic - am I right about the lack of compatibility?
I have the mojo and the 300r which can stream tidal. Problem is any dap with streaming will have very poor battery life, I'm talking 4-5hrs max which is not ideal of you are out more than indoor. The mojo pairing should be a great pairing will try it later as I left it in my car :)
May 10, 2018 at 10:29 PM Post #4,187 of 23,417
That’s why you stream and store offline then turn off your WiFi
May 10, 2018 at 10:35 PM Post #4,188 of 23,417
Yep, but streaming is more convenient as you can choose playlists depending on your mood etc..
On another note, one thing I wish it was better is the case, @64Audio could have offered a better case. My Westone w80 had a big travelling case where I could have my cables, my dap, tips and my iem. This case looks ugly, feels cheap and cant ne used to store anything else
May 10, 2018 at 11:41 PM Post #4,189 of 23,417
Best DAP I've ever heard, but yes, you are correct that it doesn't have wifi so Tidal is not accessible.
May 11, 2018 at 4:39 AM Post #4,190 of 23,417
If you want to use TIDAL, you should go for SP1000. It supports music streaming on TIDAL.
May 11, 2018 at 4:56 AM Post #4,191 of 23,417
i dont think he wants to spend that kind of cash into a dap :)
so back to the u18t, the mojo brings out more details especially the soundstage and more clarity on the treble, but the combination is less forgiving for badly mastered tracks as theres a lof going on in the treble, i can almost hear a congestion. On EDM tracks its a powerful bass with clear seperation and wider soundstage.
May 11, 2018 at 4:59 AM Post #4,192 of 23,417
If you like mojo + u18 pair, hugo2 should impress you.
May 11, 2018 at 5:01 AM Post #4,193 of 23,417
one step @ a time :) i might sell my DAP + mojo and get me a hugo 2, it depends on how fast i sell
May 11, 2018 at 6:46 AM Post #4,194 of 23,417
Yes - not looking to drop $3K on a DAP at this time. Since there are no comments on the Dragonfly Red is that because folks haven't used it or is it because it's garbage with the Fourte and U12T?
May 11, 2018 at 6:53 AM Post #4,195 of 23,417
for me its mostly because, when i started i bought an OPPO Ha2 as i was looking at the DR but most people said the OPPO is better. Plus i think most, when buying 1.5k+ $ IEM/CIEMS they want what's best for their DACs/DAPs so i dont think they will look into something in the 100-200USD range. Only reviewers can give you some advice as they most likely would have a variety of gear to compare
May 11, 2018 at 7:39 AM Post #4,196 of 23,417
Yeah why are the 64 cases so bad? They are unusable, I feel like they are going to break my IEMs and I hate wrapping the cable around those posts
May 11, 2018 at 7:45 AM Post #4,197 of 23,417
Yeah, the 64 audio case isn't particularly useful.
I highly recommend the Fiio HB1 case. This case is waterproof and less bulkier than the Pelican 1010s. I've been able to store my U12 with a Toxic SW22 cable comfortably in this case.
May 11, 2018 at 7:58 AM Post #4,198 of 23,417
I really like the campfire audio cases too :) they look great also and are really soft
May 11, 2018 at 8:12 AM Post #4,199 of 23,417
Where can I buy a nice case to accommodate my dap and iem
May 11, 2018 at 9:08 AM Post #4,200 of 23,417
What you're looking for is something like Dignis Hako case with adjustable partitions to fit your daps, iems, cables, etc.
